AC Water Pump
Flatsflyer
Need to replace the AC Pump.. Any recomendations? One pump drives both AC units, should I consider two pumps off the single strainer? I had the pump go out on Saturday night in Brunswick and could not get a repalcement so neither unit worked. Maybe the best route is to buy a new one and rebuild the old one for a spare. Some place I read about using a shallow well water pump rather than a specific marine AC pump, any suggestions?
March Pumps. Single strainer, one thru hull, both units off the one pump with a "T". I wouldn't re-design a system that as worked well thus far.
You don't wanna use a non-ignition protected pump in the bilge. Most marine rated a/c pumps are.
two pumps off one thru hull isnt' ideal, if one pumps starts first, it's going to prevent the second one from priming. Ideally, for redundancy, you'd want two thru hulls, strainers, and pumps but you'd have to haul out...
indeed if you have a gas boat, stick with ignition protected pumps. marchs come in two flavor, air cooled or sealed, you need sealed on a gas boat.
on a diesel boat, I really doubt a shallow well pump would have enough flow... I use one as a fresh water pump but is dont' think it would have enough flow for AC.
for AC, you can use a small pool or hot tub pump, in fact that's what i have on right now since the POS cruisair/oberdorfer just failed... it's a 1/2 HP ITT Marlow which was on the boat when i got it, as a back up. it works great... much more flow which is what i need right now with air temps approaching 100 deg. and water temp probably in the 90s... it's putting out probably 3000gph judging by the discharge. but NOT on a gas boat!
Thanks Guys. It is on a Trawler (Diesel) and I will pull the old pump today.
Give Depco in Clearwater a call and they will hook you up with the right solution, and can probably rebuild yours too as a spare. Great place to do biz with and staffed with pump experts. 800-446-1656. If you know exactly what you want, I believe BoatFix sells March pumps at good prices.
I am an Oberdorfer man myself; our 104M feeds FIVE units from one through hull quite happily, and runs 24/7 this time of the year and at least 8/7 the rest of the year.
By the way, what do you mean by "go out"? If the motor broke down, you might try a local electric motor shop and see if they can just rebuild it...
George
Hatteras 56MY
Ditto on the Little Giant. Two A/Cs, one pump, one strainer.
It was a Cal Pump 1200 GPH, pulled the pump amd hooked up on bench. Would not run, slight drag when spinning impeller by hand. Order new one will be dellivered UPS tomorrow. FYI, called CruisAir and got a load of good information on pump sizing and installation tips. 250 GPH for each ton of AC. 12,000 BTU's equal one ton. So my 2 16,000 BTU units require about 750 GPH if level (no lift). I will lift about 2 1/2 feet, whatever you do, don't undersize pump, don't worry about oversizing. Also the length of hose run should be kept under 12 feet.
A Cal pump? You might want to see if they will give you a twofer deal because you will need a spare.... as you have already discovered once... Or if you can wait, send it back and get a March or Oberdorfer. There is a reason they cost a little more..
BTW Pascal, the only ways I can see an Oberdorfer reaching POS status is if it is not getting enough voltage or there is a clog or under-piping in the system. According the PO, mine has been in almost constant year around heating and cooling use for at least 7 years. The AC guys I use here in Hatteras Land (New Bern, NC) and down in FL speak of them rather reverently.
I agree with George Cal should send at least 2 pumps perhaps one will work for a few weeks. I have a March it uses one thru hull and a strainer and drives 2 16,000BTU units. Each AC unit has it's own output thru-hull and if either turns on the pump starts if they both turn off the pump turns off. These AC units are the modern units that draw less current and are quieter than the older AC units.
Yes, I bought another one. The one that went out was seven (7) years old. Some of the comments give me reason to think that others have had problems. But 7 years seems to be pretty good service for the cost of the pump. I don't know if they can be rebuilt as the pump is oil cooled.
George, I'm surprised too and trying to find out... voltage isnt' an issue, I have good voltage here at my marina and when on the hook never had genset issues.
maybe the Cruisair labeled pump is built to their lower specs... i dont know yet. After only a year it woudl have issues starting in winter when i dont' run the AC much. Then there was a melted connector inside the pump,I let the installer deal with that, so i'm not sure what the cause was, likely they messed it up when they connected the pump (i had many issues with their work...). lately, after not running for a couple of weeks it would take a god whack to get it to start, just like the good ole British SU fuel pumps :)
finally, when i pulled it last week, I found the impeller to be totally rotten away, the metal all eaten up. In light of the connector problem, I wonder if maybe there wasn't some electricity going thru the pump and it cause sever electrolysis on the impeller.
I know oberdorfers have a good rep. and i know that one bad pump doesn't mean much.
Cals on the other hand...
New pump arrive by UPS. I took the old one apart just for kicks. After removing the impeller, I found a set screw with an allen Wrench Head. Took out the set screw and found that the oil resovior was totally empty. Never saw any indication of oil on the exterior of the pump. I think what happened is that the oil leak into the pump housing, the impeller then sent the oil through the AC unit and it exhausted through the discharge. That would explain why I never saw an oil leak. Painted the mounting board and will install new pump tomorrow. Wife will be glad to get AC on so she can clean interior. Boats been sitting behind house since Monday night when we returned from Savannah.
Pump is not bonded and I'm not sure how I would go about doing it. The pump mounts on plastic )Circular) brackets that mount to a wooden board. There is no external wiring, the wiring is internal to the sealed unit. SS and BRonze Cover but no place to mount bonding, even the impeller case housing is some form of plastic. The lititure says that sump can be submerged and can be used in ponds, fountains and irrigation applications permently submerged.
My Little Giant has a plastic (nylon?) impeller, magnetically driven. As impeller vains do not touch walls of pump, it can run dry forever w/o damage to impeller.
Finished install this morning. I relocated the pump lower in the hull just to ensure I was below waterline. Had to replumb bronze ftiings and hoses as the angles where wrong and hoses where too short. Opened the seacock and hoses fill right to the pump, turned on pump and she "peed" immeadately, yurned on compressor, Ah, cold air felt so good.
A little off-topic but relevant to AC submersible pond pumps. I've had a backyard pond stocked with koi and other fish for the last 15 years. I've had submersible pumps fail and blow oil twice. The second failure was a Little Giant oil-cooled submersible and by the time I got home from work and saw the oil slick I'd lost half the pond stock.
Since then I've used Pondmaster magnetic drive submersible pumps. No oil in these units and they can be rebuilt. The current 1800 GPH Pondmaster I'm using now has run 24/7 for five years.
