Adjustable height table knob - how does it work?
JoeBTB
I have what I think is a Garelick eez-in adjustable height table, and it doesn't seem to hold its position any more. I tighten the knob, but the table still slides down.
The knob is a black oval shape, with a threaded end that screws into a fitting in a channel in the table pedestal. How is this intended to work? I assume the knob draws the fitting tight against the side of the pedestal? The threaded part has a nut on it, but when I screw in the knob, it bottoms out before it gets really tight. Is the threaded part supposed to have two nuts, like a jam-nut setup, to keep the nut from moving?
Here's a pic, not sure if shows enough detail, but probably someone will know what I'm talking about. Thanks...
Back out the knob, and find something that will fit in there, be creative. I'm guessing there should be a 1/4", 5/16" or 3/8" diameter piece of delrin or nylon, probably 1/4"-5/16" long. Usually it's pressed onto the end of the screw. Just don't use a bullet............
I have a seat stantion that looks almost identical to your table and it did the same thing - put it up, tighten the black handle and it would still slide down. My seat stantion has a nut on the outside of the tube through which the black-handled "screw" passes - I tightened down the nut and the chair now stays up great. I do not know if your setup is the same, but look to see if there is an external nut through which the threaded handle passes and, if it is there, try tightening it down.
Hmm, thanks, yes there is a nut, but it is on the threaded part of the handle not the pedestal. When I tighten down, it just moves farther onto the handle. Maybe a second nut will keep it from moving.
Grady, fit in where? Not sure what you mean.
Inside the leg of the table is a sliding block that has threads for the handle. Pull the handle out and pull the table all the way out and you will see the sliding block. When you put the table leg in you need to watch for the threaded hole in the block to align with the hole for the handle. When the handle is tightened it pulls the block against the table tube. When the handle is thghtened you need to also thighten the nut on the handle which keeps the handle from being unscrewed.
Joe,
A lot of mechanical locking devices use a piece of plastic or soft metal between the end of the screw and whatever it's locking in place. This keeps the screw threads from getting damaged as well as the surface it's hitting. Some screws/handles such as yours have a small diameter turned on them or even a ball machined into the ends. This allows the sacrificial/softer material to be pressed onto the end. Other devices such as the locking pedestal seat on my boat have a pocket in the casting to pop in a little barrier piece. I believe the table on my grady had a little plastic piece fall out of/off of the end of the locking screw once.
Anyways, I was assuming the nut was welded on the female tube piece to provide threads for the screw. Suggestion was to remove screw and put something in the hole, reinstall screw and see if contact is made. Again I'm assuming screw/handle was "bottoming out" at the handle end against the nut. My thought is there's a piece missing.
Other suggestion: McMaster Carr online will have a t-handle threaded item to replace that handle if you want one a size longer. If you can provide thread size and length, I'm pretty sure we can find a part number for a longer one.
Edit: 10 minutes typing just so I can edit this and say "What Silverton34 said" lmao Sounds like he's located the missing piece.
Question: Do you actually adjust the table height, or would you be just as happy if it stayed forever at the height you wanted it at?
If I didn't want to raise/lower the table I would simply pull it apart, cut a piece of 2" wooden dowel (or an old broomstick) the right length, drop it down the center of the tube and reassble. Let the table drop down on top of the dowel and that's all the farther it will go. Table will still swivel, just won't drop down.
Rod
I'll take a closer look. I thought maybe the nut needs to be tightened against the column, but that didn't seem to make sense that a tool would be required to raise/lower the table and make it stay in place.
Rod, I might actually be able to make your suggestion work. I do raise and lower, but it's either all the way up (as in the pic), or all the way down (to fill in as a berth). I could just remove the dowel or whatever in order to lower.
Thanks for the suggestions, I'm sure I'll figure something out.
