It's really pretty simple. Disconnect cable from transmission. Set shift in vessel and shift on transmission to neutral indent. Cable should be adjusted so that it easily reconnects without moving transmission shift lever. Shift in vessel to forward and insure that shift on transmission is fully forward (disconnect and see if the transmission shift is fully forward). Repeat for reverse. Test motion. Lock cable with jamb nut and your done.
While you are in there put a little Teflon grease on the transmission shift lever where the detent is and a little on the cable end spring-loaded socket-connector and under the cable's rubber boot. Same for the throttle cables.
