Ahhhhhhhhhhh
john gov.
Took the day off today, shut off my cell phone, and my son and I launched the Sea Hunt...and what a sweet ride. She floats and everything works. The Yamaha 225 four stroke is one smooth and quiet engine. Gotta get more practice docking this thing though. How come I have more trouble docking a 23' boat than I ever had with 30 or 34'?
Anyway, sure is more fun with all the open space.
john gov.
I'm guessing single vs twin issues. Knowledge of prop walk is much more important with a single.
Actually my 30' was a single, straight inboard and the 34' was a sailboat. I have to practice and get a better feel for the boats momentum, and I got to get that prop walk thing worked out. Think I might be oversteering too.
Congratulations! You got me inspired. The weather is iffy again this weekend, but I'll listen up to the NWS after dinner. Maybe a short spin is in order...
Outboards are so different than inboards that it'll take some getting used to. You have to forget a whole lot of things you knew because it's all different now. Once you get the hang of it, it'll be so much easier.
One of the things with outboards (as opposed to inboards) is since you DO have steerage in reverse, you have to turn the wheel the other way before you kick astern, otherwise the thrust will stop your turn. You can't just put the wheel over and kick ahead and astern as you do in a straight inboard.
You'll get used to it, have fun!
Nothing like a small, fast "gotohell" boat for having fun... Maneuvering, who cares?
outboards have a much farther back pivot point than an inboard and as noted above you need to steer it in the direction you want the thrust to go - forward and in reverse. Also remember that some boats have the X-factor (height of the prop relative to the back of the boat) pretty high so that it performs like a surface piercing drive when up on plane (prop half out of the water to lower friction)....the bad news is that in reverse the thrust might be hitting the transom of the boat instead of going under the hull. Makes for some wierd handling sometimes. Great to hear you got out and had a good time sans cellphones!
