Air Conditioning!!!
rduhon, You know something about the Louisiana HEAT! it is different kind of HOT!! If there is a weak link the LA heat find it!
I have not gotten the temp readings yet.
The outside 100deg, at theom 79deg that was at 3pm in a covered slip. water temp of 92deg.
I will post more info later!
One more probably useless suggestion - check your water intake to make sure that it is clear. A friend of mine was complaining about his A/C not working very well and noticed that the water flow coming out was kind of weak. Dove under the boat and pulled a plastic bag out of the intake. Problem solved.
All the best,
it's a good suggestion... plastic bag are sneaky... when the pump is off they "relax" but stay attached in one of the slit or barnacle. you open your sea cock and find a good flow yet when the pump kicks in.. no flow because the bag gas sucked in. happens to me at least once a year, usually on a sunday morning at 6am with the AC display flashing HHH.
first time it happens, i was about to go buy a new pump when i figured i had nothing to loose by going to take a look...
Jay,
I'm not sure whether you know this or not, but Robski97 is the expert in HVAC. So, take another look at his suggestions that are not, by the way, guesses, and then see where it leads you. The end result may be that you find yourself exactly where you are now, but at least you'll be taking the advice of an expert.
This is not to say that the other responses are not as qualified, but I do know, from personal experience, that Robski97 knows of what he speaks.
If the a/c repair man said the pressures are good, then there should be no water problem. If I read it right, he said the a/c repair man said it was doing all it can do. If I were you, I would believe the repair man first and foremost.
If he is there, on the boat, with all his equipment, saying the a/c is putting out all it can, then you need more a/c. Or you can try to do some type of insulating to help the a/c you already have.
10K btu is not much of an a/c for a boat, in direct sunlight, in the middle of the summer.
