(The following are my opinions only, based on actual use of the product discussed.)
That could be the difference, but perhaps not, we had a 28ftr on the one that nearly went over, the other I think was a 24... personally, we had a Rinker 232 on ours, no real problems, except getting it centered on a windy day.
The thing that happens is, and what we experienced with a 28ft sea Ray Cuddy(and this pertains to all models in my opinion) if there is a small leak in one of the bags, as you inflate, and pressure rises, the pin hole lets more and more pressure out, faster and faster, while the other side continues to expand, it was hardly noticeable until almost full inflation, now the leak is expelling air fast, and the other side is gaining quickly in volume, we're talking maybe 15 to 25 seconds from the time we noticed something was not right, to the time the boat almost flipped, the boat was perfectly centered on the lift as well...obviously, the greater the pressure the more rapid everything transpires...
(Please note, this airdock was tested prior to putting the boat on it, and it inflated fine, no leaks...why? in my opinion, There was no weight on the bellows to expel the air through the tiny hole, so it appeared perfectly normal and ready to use)
It was very scary, and I don't want to preach or damn a product... and while they have their place, I'm sure... I just hope owners will realize that in the event of something as minor as a pinhole leak, or major failure, they could cause serious damage and injury...
Please, Airdock owners! make sure you're centered, the bellows/hoses are not leaking and well maintained and keep people away from the sides, (including your slip neighbors if you share a U slip) never let anyone in, or near the boat, when you lift it or drop it in the water, and you should be okay and reduce the risk to property damage only, if something were to fail. (again, my opinion)
If anyone had experienced what we did that day, you'd realize why I feel compelled to post this. Our friends were extremely upset, and have since given up boating.
