Air Dock?
johnfron
We've just purchased a 2008 Bayliner Discovery 246 - http://www.bayliner.com/discovery_model.asp?modelid=103783. Coming from a Bayliner Classic 2452 - we really like the hardtop and the much improved amenities in the cabin.
Our boat is docked along the Erie Canal:
I've kept the bottom painted on the 2452 with a multi-season albative - as it was already painted when we purchased the boat.
As this is a chance to start new I was considering the Air Dock - http://www.airdock.com/. It would be nice not to have to paint, and possible safer with the boat out of the water.
Does anyone have any experience (good, bad, otherwise) with the AirDock, or anything similar. I've seen the JetDock, but based on the dock configuration and how the boat is loaded and unloaded - the AirDock seems to make the most sense. I'm especially interested in the durability of the Air Dock.
Thanks for any help you can provide - I appreciate it!!
I've had an Air Dock for almost 3 years now and have never had a problem with it. It's easy to install, easy to use and has kept my boat's bottom nice and clean. I totally recommend it.
Beautiful boat. I was on a 246 a couple of weeks ago. I was very impressed.
I have heard pros and cons to the airdock on BE. The pro's are that it keeps the boat out of the water. The cons are that folks have had one bladder fail and they lost the boat to Neptune.
I would go for:
--bottom paint
--Jet dock
--Float lift
I have seen folks make their own out of a couple of pontoons from a pontoon boat an air compressor and a few parts from a hardware store.
johnfron,
Check out the new Jetdock that is a combination of jet dock / air dock. Their new model will raise and lower using an air pump, but you still get the walk around feature of the jet dock. I have a regular jetdock for my 17' four winns and I just love the ability to walk around to clean and do maintenance. No chance of accidentally popping a jetdock.
I've had my Air Dock for 6 1/2 yrs with few problems. Did have a couple of leaks due to bass fishermen snagging the bladder while going by casting. The leaks are easily repaired with their patching kit. It is basically the same as a inner tube repair kit, but the material is the same as the bladders.
I've spoken to the owner of Air Dock on the phone a couple of times. He is very accessible and easy to deal with. Being the inventor, he knows all the ins and outs of the device and willingly answers questions honestly. No salesmen BS! I have PFD copies of the instructions for set up and repair that I can email to anyone who is interested. boaterbetsy [at] gmail.com. I won't respond to any emails until Tuesday. I'll be away from my computer.
One thing the owner told me is that it is very very important to not over inflate the bladders. They should just have enough air to keep all of boat including the props out of the water. I put my outdrive in "trailer" position. Vessel Assist has told me of some Air Dock failures where the bow was inflated high and one of the side bladders deflated. This will encourage the boat to slip off and fill with water. To avoid that do not inflate the bow bladder as much as the side ones. I inflate just enough to keep the bow if it gets rocked by a wake or stormy seas.
Enjoy your new boat! An Air Dock means a cleaner hull, zincs last much longer and the return on investment is about 4 yrs. I wouldn't be without mine!
I know I could go to the website and ask this, but....how much of an air dock would you need for a 35 foot double cabin?
How do you figure that out?
E - MODEL
E-sterns/E-bow
30' to 36'
up to 12.0' up to 16000 lb. $5405.00
OK, so if I had 160 truck inner-tubes all tied together....?
I helped raise a 20' inboard with Inner tubes. It was in about 30' of water.
The diver took inner tubes down. One or two at a time (I dont remember much about that part) and stashed them. Finally he took the air hose down and began to fill the tubes.
Soon he was rocking the boat to loosen it from the mud and up she came. When we got the Gunnels clear, we started the pumps and towed a dry boat back home.
He probably only had 10 or so tubes.
Thanks for all the great feedback I appreciate it! I think I have a much better understanding of the pros and cons of the Air Dock. It seems like it would be a good idea - but I'm unsure if it's the type of solution that I'm looking for.
You can see the size needed for your boat if you click on the Boat Sizes page on the Air Dock web site.
Thud - It sounds like the old MythBusters ping-pong ball episode. I'm sure you could use any thing to raise a sunken vessel if it was buoyant enough or you could easily increase it's buoyancy.... How about raising a vessel with empty 2 liter bottles - or even better empty Kaliks (I'm not sure if that would really work - but I'm willing to empty whatever it takes to find out!)...
I have a cradle type lift that hangs inside a boathouse, have also used the Hydrohoist lifts. I don't particulary like the looks of the Airdock, but of course I have never actually seen or used one, so I could be wrong. It just seems the other lifts would be more stable (Cradle, HydroHoist, or JetDock). I personally like the cradle lift, I like the fact that everthing is hanging out of the water and not subject to any type of water fluctuation. In your situation you could sink four pilings to support the lift, cost would probably be more than a JetDock but lest than a HydroHoist. The manufacture of the one I have is Doozie.
Originally posted by Thudpucker
OK, so if I had 160 truck inner-tubes all tied together....?...
YEAH BUDDY. That would go over big at any marina. And one can only imagine the immediate escalation in property values in the local area!!!
Iam i reading this right??.... If one of the tubes deflate, your boat will capsize? Thats insane....far to great a risk. Things filled with air go flat all the time for no good reason. I cant imagine walking up to my boat seeing it on its side at the bottom of my slip and only half the Airdock inflated. Iam I missing something, because all the other reviews on the Airdock are great, but like I said , MAJOR risk.
I live near a large lake. Lots of Money around the edges, and lots of boats on those floating docks.
They remind me of a Boat Trailer frame mounted on two large tubes.
Pleny strong enough, good wear capabilities (some of them rub on the dock constantly) I've seen some with low air in the tubes but the boat is still up out of the water.
Could be they have another tube inside the outer tube.
The boats in the floating docks look so much better than the ones with all the moss streaming out from the outdrives and other parts in the water.
There's also some mechanical methods to raise the boat up out of the water.
The advantage of the floating docks is if you have a fluctuating water level, sometimes the floats are sitting on the mud or close, but never very far from the water. (if you have water!)
Thudpucker, the Airdock is 3 big air mattress's that your boat sits on, the Airdock doesnt have a frame like the other lifts, its a cool idea , just seems risky if it will flip your boat if one side goes flat. Hopefully thats not really the case, because i would like to get one.
I have had my Air Dock for 7 years now. Yes, there is an "inner" bladder which is always inflated as well as the outer bladder which deflates to put the boat in the water and drive it off.
I have had several instances of one of the three bladders deflating accidentally and have NEVER had my boat in danger of sinking. However, I have heard of a couple of situations where this did happen. If the bladders are over inflated and one deflates and your boat does not have enough freeboard, it may tip the stern enough so that water gets in over the gunwale. Only inflate the bladders enough to just clear the outdrive from the water. It is important that your outdrive be in the "trailer" position or tilted as high as possible.
"Raised Boat Is Not Stable From Side to Side:
1.) Make sure boat is centered on air chambers.
2.) Make sure boat is not raised more than 4 or 5 inches out of the water at the stern and two
inches in the area between the front and stern chambers.
3.) Call Air-Dock for assistance (727-577-0151)."
I have a .pfd file which Air Dock sent me with more info. Email me if you would like a copy: boaterbetsy at gmail dot com. The website also has info for inboards.
Bottom line, if the Air Dock is properly installed and inflated, it is extremely stable even in stormy, windy conditions. But probably not tornadoes or hurricanes!!!!
Another advantage is the boat's hull is supported similar to the water. Lifts with bunks support it like a trailer which isn't good if you have a heavy boat.
After 7 years, I would not be without my air dock!
Thanks Flutterby....Thats good to hear, because i really want an Airdock.
A friend of mine has one, had it 2 years now and so far no problems and he's been happy with it. He uses it for a 23' center console.
ccstone---go for it! The first mistake I made after I got it was not making sure the valves were closed tightly before I left. One of the bladders leaked out the air. Boy was I embarrassed when the installer told me why it deflated! Sort of like forgetting to plug in an appliance and then calling a repairman......
I've saved money by not needing bottom paint and avoiding stern drive corrosion. And I love the fact I no longer have to haul the boat and clean the bottom 3 times a summer!
The owner of Air Dock is extremely helpful, so contact him if you have questions or problems. But review the entire website before you call. He has an awful lot of good info posted.
