alpha 1 drive generation ??
Brucesrv197
I have a mercruiser 260 Alpha 1 drive from a 1981 Searay the serial # on the bell housing is 5834485 and the one on the unit is 5925796_1_50R ...... can anyone tell me if this is a Gen 1 or 2? and would I be able to switch out the lower gear unit with any other mercruiser alpha 1 with different rating (i.e. 400..instead of a 260?)
R/MR/Alpha One used the same gearsets from 1973 - 1990. You could use ratios:
1:94
1:81
1:62
1:47
It all depends on the engine application. If the leg was used on say a 4 cylinder and you install a V8, you may not even get out of your own way when you accelerate. You may want to talk to someone with knowledge in that area.
The gear ratio oh the drive is 1.50 to 1.
That was the standard ratio on the higher HP
packages back then. If you are asking if the
1981 drive will handle more power than 260
the answer is no. Horsepower ratings back then
were very generous anyway. The probable actual
HP was more like 235, and at a lower max RPM
than todays motors.
So if I need a new lower unit, would it matter what ratio the drive I get it from? Are the drive gears in the lower unit matched to the HP rating of the upper unit? i.e. if I put a lower drive unit from a 1:94 on with an upper ratio 1:50 will this matter?
or are the lower gear units the same and just the upper ratios are different to handle the HP?
