AM FM CD receiver !
HPLou
Good day.
I need to replace the original Craig audio receiver in my boat. I'd like to be able to play MP3's and the actual radio as only AMFM4tracks cassette. Can I install a Car Receiver instead of a Marine receiver ?
Thank you.
Louis
HPLou
Sure you can, and I have had both. The main difference is generally waterproof front controls and case seals as well as waterproof circuit boards. If your radio location is not in jeopardy from the elements, then at least be sure and get a unit that is robust enough to not "skip" at the slightest bump while playing mp3s
Stan
Sure. I have a Sony, with the optional 6-CD changer. Just make sure it's out of the elements.
I have the Boss marine. I like those because they have the Aux jacks so yiu can use your Ipod or mp3 player threw them. Just need the adapter cable. I also like the wired remote so you can put it on the fly bridge or on the back of boat.
I just added two Sony units to my boat last season - If you have a ipod - there is a control unit you can plug into both - the remote will also show the contents of your Ipod. Sirius satellite also an option. Very good units. For easy operation, they also have a Aux jack in the front for just plugging in the ipod. Oh yea, if you buy the Ipod controller it will also charge your Ipod in the cradle.
Thank you very much for the replies.
What Sony model (Mike) should I be looking for?
HPLou
I bought the Sony CDX-R505X - Xplod for my main unit. The second one I am not sure of the model but it was the base model with aux front input. The main unit is in the cabin and the basic unit is in the cockpit. I have run a line to the aux input from the main unit so I can control both with the xplod remote mounted at the helm.
hey hplou--- You might want to check out the Aquatic Aq cd player. It is really one of a kind on the market. You can buy a wired remote sensor and a wireless remote. What is nice about this is when you install the wired remote sensor at the helm and then you can use the wireless remote up to 50 ft away and control the unit. The wireless remote is waterproof and will float. I don't know about the quality of the performance but it sure sounds convenient.
art
Mine is protected from the elements, so I just got a normal car stereo and put it in last month. I got a Sony CDX-GT310, which I liked because it has a front "aux-in" so I can just plug an ipod directly into the front of it. There are cheaper and more expensive versions, the 310 seemed right for what I wanted -- satellite ready, and better signal-to-noise than the 210.
Here is an idea though: If your car stereo has the AUX jacks for RCA cables in the rear, you can purchase a 2 to 1 conversion plug for just a couple of dollars. This will allow the Ipod/MP3 player to play on any stereo. For those who do not know; the RCA inputs are silver and round. It is the same as the plugs on most VCR's and TV's.
