Anchor ball--do they work?
Cyprox
I just bought a smaller boat. My older one had a windlass that made retrieving an anchor easy on the back.
Needless to say the new one does not have one. I have, several years ago, heard of anchor balls to retrieve the anchor. Do they work? How?
Thanks. I looked it up. Seems easy enough. Has anyone had any experience with it?
How small is your boat?
Do you have a place to store the ball?
They do work but if space is a premium....you might be better off doing it the old fashioned way. Let the boat do the work!!!
You still have to get the line into the rope locker with the ball so either way it's a pain to deal with the line.
Jonathan
They work great, I used to use one all the time . The ball floats the anchor at the surface so retrieving everything at your leisure is almost effortless. Just about everyone offsore uses one if anchoring without a kazillion feet of line or chain on a windless. However, they do require room to manuever so they aren't particularly appropriate in crowded anchorages.
It takes a lot of room on the surface. The length of the Anchor line.
Its kind of a chore, but it takes the chore part out of retriveing all that line.
We fished for Halibut in 350' of water which translates to 450' of line, plus the chain and Anchor, so make sure the ball is big enough to float all that.
Somewhere you can find 'halibut ground line' by the Skate. (1200')
That is a non-stretch line that does have a bit of stretch to it and a whopping 2000lbs of tensile strength.
Its also wear resistant and handles easy.
Its small, does not kink readily and IMHO is the very best Anchor line available. You can store a whole Skate in a plastic garbage can.
That's what I used. I had a 55Lb Anchor, a 3" steel ring and a 100" float.
Agree with above, not to be used in a crowded anchorage, although that would be amusing to watch.
Offshore fishing, everyone seems to use them, get the larger ball size, bigger is better, and just put a split ring through the ball eye.
As far as the anchor locker goes, that's what fish totes/baskets are for. Never saw anyone hand feed 600' of line into one anyways.
