Anchor line question
ctcruiser
On the end of my rope anchore line the meteal eye has rusted and I bent it on accident last year when it got hung up on something. Can I rplace this without having to resplice the line?
I think you might have a hard time getting a new one in the loop withoout resplicing. But maybe, if you soak the loop in warm water with a softener to give it a little stretch and loosen it up, you might be able to force it in.
I've always been pretty good at splicing, so I just cut off the offending part and splice a new one into the fresh, undamaged end. I suppose you -could- jam a new on in there, but if you, using human power, can get the eye into the loop, then odds are that that under stress the eye could slip out...
Just my opinion. As stated I just replace the ends, so I have not tried the alternative.
I would resplice but the line is in good shape not frayed at all and to be honest I haven’t a clue how to splice a line and I think I would probably suck at it. So if there is any other way. I did see this thing westmarine sell clamps on the line and uses pins o secur it and the clame it is as storng as a real splice but I don't know????
What condition is your rode in other then this issue? It may be better to purchase new rode with the eye already spliced into it. You can use the old line for extra dock lines or a spare anchor rode.
Splicing three stand line is just about as simple as tying a knot. Go to New England Ropes--splices or Sampson ropes, splices. There are other sites which show how to slice, but not sure if we are allowed to post those links...
Don't try pins or to force another THIMBLE into the line. Just re-splice it. You need to learn how to do that now. Actually its fun.
Splicing three strand is not hard as Bob stated, but a little more difficult than tying a knot. The tricky part seems to be starting the 3rd strand. Once that is done right then the rest is a breeze; over one then under one.
'tain't a breeze for me---'cause I have arthritis in my fingers and very little strength. So I have to purchase pre-spliced gear......
I hope posting this is not verboten...it's a great site for someone who wants to work with knots, etc.
Splicing IS fun, and very satisfying and you can be proud of your docklines and fender whips if you made them.
http://www dot animatedknots dot com
Be careful about the metal clasps that you clip to the bow eye. Some are just galvanized metal and have a fraction of the strength of the line itself (the weak link...as you already found out)
I do not think the metal's eye is intended to add strength per say. It's there to keep the rope from fraying as well to provide a larger radius and spread the load on all the strands.
ctcruiser
May be a terminology thing going on here. Are you talking about a thimble?
Or hook
Ditto to what's been said about splicing. Somewhere I have an old book called the "Sea Scout Manual" and it has all the splices in it. Eye splices are a piece of cake. It's a pleasant activity for an afternoon to have a beverage or two, listen to a ball game, and splice a few lines.
OTOH, the end splice kills me, I can't seem to start that without looking up the initial setup every time and even then I struggle. And double braid, I've looked at those diagrams a hundred times, forget it. Those I will buy.
Liz, you may be trying it with older line. Older line is usually better because if it has some stiffness, it doesn't just try to devolve into a mop right away. But for you, nice soft pliable line might not be such a challenge.
I will give the splicing a try. The rode is in good shape and the other reason I don't want to trade it out is because the line is color coded and is great when I am letting line out from my windless I can't seem to find color coded line other then from good automatic and it's not cheap.
You could try placing an ad in Craigs list for someone in your area to splice it. There is a guy on Long Island who from time to time advertises he does splicing or go to a local boatyard. I'm not sure the anchor line is the best place to practice your first splice.
While you are in the mood to resplice the thimble on your rode consider this. Its likely that only about half the total length of your rode ever came out of the locker. When I respliced my rode I first removed and reversed all the rode so I was now using the "clean" end of the rode. If you chose to go this route its also advisable to first remove the anchor and then, while cruising slowly in a straight line, feed all the rode out so it trails behind the boat. This will remove any twists or coils that have developed. You can then begin bringing the rode in and coiling in in the locker "dirty end" first. Just make certain you have a second person aft to make sure it doesn't get into your prop.
MikeeH. I did that when I upgraded my anchor. It worked out perfectly. I had an SO then who was an expert at splicing and enjoyed doing it.
ronp, I know what you are saying, but I still do not have the strength to pull the strands tight enough for a nice neat splice. Oh well, my problems could be a lot owrse, so I won't complain.
Yep, what he said. It's called 'end-for-ending' and is common practice with towlines as well as anchor lines. That's why new towlines and anchorlines in the professional world are usually made up with an eye (or thimble, if that be the case) on both ends.
