Anchor rode diameter?
VTBoater
I have a good length of 3 strand nylon anchor rode picked up cheap, it looks just under 1/2 inch, likely 7/16 stuff, in good shape. Can I use it for this heavy boat as my main anchor rode? Does an anchor rode ever break, or is it the anchor that will drag and lose hold before that ever happens?
The existing rode looked short, old, and rough, it I can remember back that far.
I've had the rode let loose before the anchor. I feel this was due to chafing that weakened it a bit.
I'd stay at 1/2 inch min for your boat.
What kind of boat? I had 3/8” break during a Nor’Easter on a 20 foot boat. The rode was not even a season old. It broke between the anchor bit and the shackle on the anchor…no chafe. Not sure if the rode was defective or not. I stepped up to 1/2" for normal circumstances and 5/8' on a storm setup (learned my lesson). I only use 5/8” on my 24 footer now.
That rode is way to small a diameter. You need larger diameter for more chafe protection. Go with 5/8.
I picked up a 13lb anchor, some chain, and about 150ft of that line today from a local person on craigslist for 50 bucks. Was hoping the line was big enough to swap out the main anchor rode, but it isn't, so I won't do that. It will make a good stern anchor setup, the boat didn't come with one.
Thanks for the advice, right on as always.
James
I think your making a wise decesion. I only have a 26 footer. I use the little 13lb anchor and rode the dealer supplied as the stern anchor or use it to anchor the jet ski. Get the right size anchor for the boat and when the winds pick up you'll be able to feel better. I never feel completely at ease when the wind is 40+ mph.
Good choice. Ground tackle is not the place to skimp.
Personal opinion of course, but for that size boat I would use the 1/2" line as opposed to the 5/8" because of the "stretchability" factor.
The 1/2" stretching more under load takes a lot of strain off the anchor, lessening the chances of dragging.
Previous boat was 34' and ground tackle was 35 lb CQR, 200' of 3 strand, and 30 or 50' of chain. Did a lot of overnighting in VTboaters home waters and never a problem.
Good luck and have a great summer.
Ron
