Anchor rode - how much?
HarlenW
I now have 25' of chain and 120' of line for my 38 ft Mainship Trawler and I want to increase this, especially adding a greater ratio of chain. I boat in the inland waters of the Pacific Northwest and haven't done any anchoring but want to change that. The chain I have is 5/16 Grade 40 galvanized.
What is the recommended length of rode for my boat?
What are the pros and cons of all chain vs. chain and line?
Is it acceptable to add chain to what I already have?
A friend suggested using what I have as a stern or auxiliary anchor and starting over for the main anchor. Comments?
Thanks!
I can sort of answer a few of those questions:
"What is the recommended length of rode for my boat?"
Not exactly the correct question, it should be "What total length rode do I need". Boat length has little to do with it... When anchoring you want a rode that is 7 times longer than the depth plus the distance from the water lint to the top of the deck. ie: The top of the bow is 7 ft above the water, and I want to anchor in 20 ( corrected from 25 ) ft water, I need: ( 7 + 20 ) times 7, or 189 ft ( plus a few to go from the bow roller down the deck hole to be tied off in the anchor locker ), or about 200 ft total length. Simply figure out what your max desired anchor depth will be ( don't forget anchoring in "undesirable places" in an emergency ), then size the rode length to fit. Some boaters will accept a shorter rode when anchoring ( I am not one of them ).
I'll leave the next two Q's to those who have all-chain anchor rodes...
"A friend suggested using what I have as a stern or auxiliary anchor and starting over for the main anchor. Comments?"
I have always felt that "redundancy is your friend", so I have more than one prepared anchor rode aboard ( as well as spare anchors ). I think your friend is on the correct track. 0n rare occasions I have had use for a second anchor ( though I like all to be large ). So, yes, keeping the current one as a "spare" is a good plan in my book. Put an anchor on it, too. The spare may be used: as a spare, in case you lose the "primary", the second anchor in a "bimini rig", a stern anchor in the event you need to force the vessel to stay aligned with something ( like the beach ), or used to kedge the vessel off of the sandbar that you do not intend to run aground upon. ( Apologies to the Teachers on the forum. That one ran on a bit. :))
I think your friends right.
You can't go wrong with all chain. But at the same time, it can add a lot of weight to your bow.
Depending on the depth of the water you tend to anchor in, I'd consider going to at least 50 feet of high-tensile chain with at least 200 feet of rode.
What type and size is your anchor?
I think in the example above I would go with 224'. Depth equals 25', plus 7' above surface, equals 32', times 7 equals 224. Then a few feet extra and you should be good, but 200 may not be enough. The guy that told you to use your current set up as a back up or spare, was probably thinking since you want to add chain, that it would be easier and possibly stronger to get a new chain of the length you want, and only have to make one splice between the chain and the new anchor line.
What is the max depth you will want to anchor in? Get that, apply the correct formula for the rode, get a quality anchor depending on what kind of bottom you plan on anchoring in, and maybe two or three different type anchors, so you are prepared for the different bottom types you may encounter.
I am against all chain rodes. They can be very hard on your boat in waves to the point of damaging the boat. Since you are in the PNW I am not familiar with the bottoms but I think rocks when I think PNW. I have 50 feet of 3/4 chain and 300 feet of line. It is always a good idea to have a spare. My boat is a 40 plus foot Mainship Sedan Bridge I normally anchor in 6 to 10 feet of water however I believe in overkill when it comes to safety devices on the boat, which I consider the windlass, rode and anchor. I have 2 spare anchors one is a Sea-Anchor which technically isn't an anchor but if I was ever out in the Ocean, lost power and in a bad storm it would be my first choice. Chain will last longer rubbing against a rocky bottom than the line.
"Depth equals 25'"
<< busted! >>
Typo. My intent was 20 feet water depth... OOps. ( Original now stands corrected )
Harlen:
What do you mean by the “inland waters” ? Fresh water lakes?
“I boat in the inland waters of the Pacific Northwest and haven’t done any anchoring ….”
I'm the opposite of Billy. I like all chain and have never seen the damage he refers to.
I'm with Bruce on this. A properly designed and used snubber pretty much eliminates the chance of chain doing any damage to the boat.
All-chain vs. combination rode? The more chain in a primary anchor rode the better as far as I'm concerned. Chain will lie at a lower angle to the anchor than rope. But, boat size and weight is a big consideration. I sure don't want 200 lbs. of chain sitting in the bow of my 26' cruiser so I use 30' of chain with premium quality three-strand anchor line.
You want enough rode to equal seven times the deepest water depth in which you plan to anchor. Rode length includes the chain if you use a combination rode.
If you decide to use your existing rode for secondary anchor, take a look at the chain length. I often put out a secondary anchor to limit swing if an anchorage gets crowded. That can be a couple of days after setting the main anchor so I row the secondary out in a dink. Ten feet of chain on the secondary anchor works fine and is a lot easier to handle in a rowboat than twenty-five.
The use of all chain is a no brainer, on a Trawler the weight on the bow is not an issue. Anyone with any experience will also always use an anchor bridle between your front deck cleats and just above where the chain comes in contact with water. With all chain you can reduce your scope significantly and still be safe. I have a 40 pound anchor and 300' feet of chain and have never dragged even when anchored inside of inlets with real strong currents. My lunch hook is 200' of braid with 50' of chain, it has not been used in several years ecept when tying the boat off in the canal behind my house during hurricane warnings.
Originally posted by Old_Salt
Harlen:
I just meant that I don't go offshore or even near the shores of the Pacific. So, Puget Sound, Juan De Fuca Strait and north into the Canadian islands. “Inland waters” may not have been the correct term. But there are lots of anchoring opportunities.
I assume you have a windless?
At minimum I would double up an both the chain and rode, 50’ of chain & 250-300’ of rode
I use a 66lb Bruce anchor with 300’ of chain as my main anchor, my last 2 boats had all chain as well- If your concerned about any chain noise etc just buy or make a anchor chain snubber. I also have a Fortress with 300’ of rode as back up. if you go all chain make sure you have a bolt cutter on board as well as a marker float if you have to cut the chain!
In reference to adding more chain to your existing chain on your rode see the thread I started the other day:
http://www.boatered.com/forum/topic.asp?TOPIC_ID=126685
We don't have a trawler but our 38' sedan now will have 250' of 5/8" line and 50' of chain for our rode. People on Lanier have pretty much no concept of scope. If I let out as much as 2 or 3:1 scope on my rode i will have probably 5 boats anchor right on top of my anchor and then be shocked when I swing so wide and they end up in my way. Granted, we have no currents or anything to deal with but many of the coves we anchor in are in 30-50' of water!
Harlen:
I saw “Port Ludlow” as your homeport, but wanted to make certain you were referring to Puget Sound as “inland waters”.
We both know that one can anchor in 20’ of water in the Pacific Northwest, but we also know that it is necessary to anchor to accommodate the conditions at High Water, which goes 15-20’ where we reside. If you go to Prince Rupert, make that 25’, and Southeast Alaska will take you to 28’ in places. If you should anchor at the 10 fathom mark (60’) in Puget Sound, and I’m on the 20 meter curve (64’) in Desolation Sound, we can have 75-82’ of water under the boat at high water. 8:1 scope would require 600-656’ (plus freeboard) of rode. I go up the B.C. inlets and to Southeast with a Commander 30, a 33 lb. Bruce, 60’ of chain, and 300’ of nylon. I have anchored in 80’ of water (at Low Water). I sleep well at 3:1 scopes.
If you intend to boat and anchor in the salt water (Puget Sound, B.C., Inside Passage, Southeast Alaska) you might check out a discussion that a couple of Northwest boaters participated in a while back. I think your question gets answered by Northwest boaters here:
http://www.boatered.com/forum/topic.asp?TOPIC_ID=107974
Kurt (mixman) pulled the PNW boaters into the fray with the statement, “I too have seen the 3:1 scope idiots.” in his post dated Oct.24, 2007. As a PNW idiot, I shared a couple of laughs with him.
The Pacific Northwest is a great area to boat in, and the addition of “anchoring out” will add a lot of pleasure to your cruises.
Some boaters have no idea on how to anchor. They stop the boat about 20' in front of me, drop anchor, and let out 20' of rode. A minute later the boats are almost touching and they look at me like I caused this.
Where I boat the most popular place is the sandbar during the day. 3:1 scope is about max due to it being congested. Even with that there are people driving across the rode, like they can't see the line coming from the my bow. I only have 6' of chain with a size larger danforth and I am concerned that someone may cut the rope with a prop as they go by. I'm thinking of going with 50' of chain because of that.
I fully understand the issue when anchoring with "ignorant neighbors", but you still need to carry enough ground tackle to anchor properly when Mother Nature starts playing pranks. Carry the right rode. If you "anchor short" around neighbors, having "too much" rode won't matter. But if you get caught out in a storm you definitely want enough rode to anchor properly, so that is the amount to have in the locker. Imho.
I carry 300 feet of chain on my 43 foot Tiara. I mostly anchor in 25-30 feet of water but as Old Salt said you must consider the tide range. I'm comfortable at 3:1 but prefer 4 or 5 to 1. I currently use a 45 lb. Delta but may go up one more size.
Before running out & spending $$$$ on a whole new anchoring system ask yourself if the anchor, chain & line combo that you already have works in areas where you anchor?
My personal preference as a 30-40 overnight per year, majority on anchor, is a boatlength of chain plus line. Most nights we are in under 10' of water so we put out all the chain, about 30' to the bottom, plus rode to the deck. Never had a failure.
With an all chain system what are you going to do when the day comes that you have winch failure. How are you going to get all that weight up, especially if in deep water???
You use a hand winch. Unfortunately, on our boat the way Silverton designed the hide away windlass, you can't get a full turn with the hand winch. Would love to have a way of extending part of our hand winch so we can get a full turn on it.
