anchor rode
  • Thread starter Thread starter CW
  • Start date Start date
CW
I have been reading the threads on anchors and anchor rodes on the forum for several years. I have several danforth and fortress anchors that I use often. I have tried all chain and all rope and combos and have not been able to tell much difference in the holding or setting speed of anyone over the other. I almost always anchor in sand or soft mud. I have noticed that once the wind gets over fifteen knots that be it all chain or all rope the rode is tight and not touching the bottom. My question is, has there been any test on fortress anchors to see if the type of rode affects the holding power. I know that chain protects from abrasive ware form the bottom.
I think you meant "anchor rode"...
An anchor rode with no chain almost always stinks. You really need at least some chain. The chain not only helps with abrasion problems, but helps set ( and re-set ) the anchor, as well as acting as a shock absorber.
As far as testing is concerned, no I have seen no tests, but the chain does not directly affect holding power very much on any anchor. It helps reduce sudden shocks and averages the load on the anchor. The chain would affect all anchor types about the same.
If you use a Fortress without chain, ( in this particular case ) it will "sail" easily when setting the anchor and make initial setting much more difficult. It will also impede "re-set" due to the same issue.
I'll agree with Bill that chain in itself does not increase the holding power of an anchor. I've been guilty of saying that myself when what I should say is that additional chain is very effective in allowing an anchor to set properly and stay set, utilizing the full holding power of the anchor.
A few benefits of using more chain:
Chain helps to keep the rode angle low so the anchor can work as designed, especially when less than 8-1 scope is used on a plow or danforth type. With chain, a rode takes a lot more wind and acts like a shock absorber between the boat and the anchor before it finally pulls taut. Under light wind or current a boat (especially smaller a smaller boat) is more like to wander around the end of the extended chain than wander around the anchor: turning around an anchor can increase the chances of breaking loose and dragging anchor. Chain also provides resistance to swing because it tends to dig into the bottom. Finally, additional chain will help to counteract anchor sailing if you are trying to set anchor in higher wind or current conditions by doing a better job of pulling the anchor to the bottom than line.
Sand and soft mud are the same conditions I anchor in all the time. I've used Fortress and Danforth with out chain and that worked fine. I used to sleep with one eye open with that set up in a protected anchorage and never had a problem but never felt good about it either. We now have a Delta with about 30 feet of chain and a synthetic rode. I now sleep soundly and don't bother to get up for storms to check for dragging. We tend to anchor in the same spot and use a lot of scope. Once that baby is set, which takes about 30 seconds, it only digs in deeper when the wind kicks up. Sometimes you really have to work to get it out of the mud.
Originally posted by CW
I think the type of rode affects the holding power of any anchor. "Catenary" is a term you need to understand. Fiber rope (nylon, not dacron) stretches; chain does not. A combination of the two (nylon and chain) is good. I leave the particulars to others.
By no means is the following a "rule", but usually the advice is to have:
Anchor, then a length of chain equal in length to one-half your boat length to one boat length, then nylon line from there onward. For smaller boats, this seems to usually produce reasonable results ( and I therefore consider it a "rule of thumb" ). In any event, it is a good starting point. For certain types of vessels and/or certain areas, this is not necessarily a good setup.
Every vessel has varying requirements, dependant upon the boat length, type, weight, shape, the types of seas and bottoms encountered and the "sleep limit" of the Captain. There are often other requirements that might need to be addressed. ( incl. the "Sleep Limit" of the spouse/partner. ) Because of the unique nature of each situation, I would expect that your results will vary to some extent from everyone else's here. So try several methods before settling on one primary method. Note that many experienced boaters carry a second ( or third, etc ) complete anchor and rode as a spare or for when conditions vary from the "norm".
boathandler, yes, it is likely that the type of rode affects the holding power of any anchor. But it is likely that any improvement in performance would equally useful to most anchor types. ie: Having a good rode is a good idea, whichever anchor you choose. It is also likely true that the type of anchor affects the holding power of the anchoring system regardless the type of rode. The key is getting both a good rode and the most appropriate anchor for the most common situations ( or, for paranoids like me, for the most severe conditions that might occur. )
