Anchoring etiquette
boating_rob
Yesterday we went to a anchorage that we normally go to. Since the weather was not the best and the forecast was not the best there were not allot of boats there. We anchored close to shore and since the light wind was towards the beach we did not need our stern anchor out. We did sway a little but not allot and when we anchored no other boats were near us.
A few hours later when the sun came out more boats showed up at the anchorage. One boat anchored right next to us and then dropped its stern anchor barely leaving me enough room to swing.
The wind changed a little and we started to swing towards them. We ended up about 5 feet from their boat and they all gave us dirty looks like why is my boat coming close to them. I was in shallow enough where I was nice enough and valued my boat to move the boat away from them and hold it so it would now swing into them. Then 2 of their buddies decide to raft up to them leaving me hardly any room. WTF?
Once my daughter was done swimming I pulled the boat out into deeper water away from them to avoid a confrontation since we were leaving in about an hour.
I believe I was in the right to NOT have to move since I was anchored there first. Again I think its time for mandatory testing/classes for all boaters.
yes you were correct however the rule about stern anchors traditionally has been to follow local custom, if folks normally use a stern anchor them you will cause fewer problems if you do as well.
The problem always seems to be that with plenty of room some idiots always want to anchor right next to previously anchored boats. I swear wherever I anchor the next boat will plant themselves right on top and then tell me I should move if I dont like it as did a big Hatteras crew not long ago.
Comment removed due to overwhelming and totally uncalled for political commentary that has no place in the ATC thread. THe offender has been taken out back and shot, His carcass will be gutted and used as chum while the remainder will be turned into a fender to be used on some dictators boat when that dictator moves to the US, thus a proper boating connection allowing htis response to stay in the ATC forum until Les gets fed up with my sarcasm cynasism and deletes it.
Have a nice day. Somewhere else
boating rob,
When in an anchorage that can support multiple boats it's common courtesy to set a stern anchor to stop the boat from swinging and use less beachfront. Although there was no one around there was later...you should have setup a stern anchor when you got company if you hadn't already done so. Just because you got there first doesn't excuse you from being courteous.
Just my .02
Yeah Bruce, seen that a lot too. Happened to me a few weeks ago at Ocracoke; lots and lots of room and this guy comes right next to us. I guess some people figure "well that must be a good place to anchor...."
The actual etiquette is for new boats to anchor in whatever manner the boats already there are anchored. The existing boats have every right to ask the new guy to move away if they are not comfortable. I have asked others (like the dude at O) and others have asked me when my boat seemed a little "intimidating" always on a first-there basis.
George
Hatteras 56MY
You were in Croton Rob?
The guy who pulled in after you should have given you room to swing. There is no hard and fast rule that everyone HAS to use a stern anchor there. That is just crap.
Being courteous is giving a boat that is at anchor enough room to swing, sorry to disagree with you Perry. Not everyone is comfortable with using stern anchors, also if you use your gas genset you will be much safer if your boat swings with the wind and not stern anchored.
You want the good real estate, get there early.
Robyns Nest - yes we were in Croton. Passed you by West Point when we went for a ride first.
Like I said in my original post the anchorage was empty due to the weather(forecast) that is why I chose not to put our the stern anchor. I was in standing water ~4-5 feet and only had about 25-30ft of anchor line out. Leaving PLENTY of room along the beach for anyone else that stopped by.
Speaking of stern anchors (don't mean to kidnap this thread) there is a question I have discussed many times with friends so I'd like to have your opinion.
Is the proper procedure to set the stern anchor first then the bow anchor or the bow anchor first then the stern anchor?
Bow first, then stern.
Rob, I was going to go to Croton yesterday, but didn't want to deal with a stern, so went to Bowline.
I agree, that since you were there first, the other boat should have respected your "space" and allowed for you to swing. The problem is, that most people in close do use sterns, usually, on a weekend, if you don't want to stern, you anchor pretty far out.
In the Delta [protected waters, but strong currents and can be windy] I've done it both ways. When I am by myself, I've found it easier to drop my stern anchor and let the rode feed off of my shoulder while I slowly drive from the helm. When my bow is in position, I let out by bow anchor and shut off the engine. Then I am able to adjust the boat between the two anchors to where I want it to be. Of course, if I'm anchoring at a beach, the bow anchor goes out first, then I back toward the beach to place my stern anchor........
Originally posted by Shadowcruzr
You just cant teach them Class. Look at the Pres...
It's the old restaurant mentallity: If there are 50 empty table, they seat you next to someone else...
THe other boaters were rude.
Is it possibly for you to comment on something without making a political statement all the time?
Perry,
I disagree. The boats around you have to dictate ur options. If everyone is on on a single anchor u have to do the same. Not doing so is inconsiderate. That said if you anchor adj to a boat with bow and stern hooks out , you have to do the same or pick another spot.
Rob,
I hear ya...I would say that it would depend on what's the local custom. On LI, it's expected that you use 2 anchors for beaching purposes and that you don't swing. If you want a single hook then deeper you go. Places like Great Gun get tightly packed with boats and there's really no room to swing. Plus you have all the kids having to deal with a boat that's swinging with the wind/current/tide and that could separate a small child from safety if the boat swings and they're on the wrong side.
My comment is for anchoring a boat for the purpose of spending time off the boat and on the beach.
I understand the usage for a stern anchor and I have one. With 5 boats in the whole anchorage I did not feel I needed one. This was at 2:00 in the afternoon. If the place was crowded then I agree and would have put out the stern anchor. Since no other boats were NEAR the beach when I got there I did not feel the need to one since the wind was holding the boat with the stern towards the beach.
boating rob,
I certainly didn't mean to come off like an arse, if I did I apologize. I am not familiar with where you boat so I can't comment on location. On LI, there's not alot of these anchorage locations and they typically fill up as the day progresses. In addition, there's not much real estate to go around so the smaller the footprint the better.
Perry,
I didnt see the beaching reference. If yes you were stern to the beach then yes I get the two anchors thing. Like Boating Rob stated this happens alot that some J/o comes in and is completely clueless of whats going on around him.
FYI We were over at the beach hut on thursday on the canal. Nice place. ( small beach )
Er...Capt. Bill1, is that not a form of political statement right in your signature line?
As is the norm, he who gets there first gets the best spot & others must anchor around him. However, in a spot, especially a busy spot where it is the norm for people to set a stern anchor to the beach for convenience to get to the cooler, I would call it inconsiderate if I found somebody hogging prime beach space by letting their boat swing on a single hook.
if you got there first, you have right of swing unless obviously the local customs are that everyone use a stern anchor...
about stern anchor, that works for a small boat but not for a larger vessel so saying that you should be courteous and use a stern anchor is not exactly accurate. Stern anchors are fine for small boat or when anchored for a few hours during the day. they can be downright dangerous if the weather goes down on you... and setting a stern anchor with a large boat is major PITA.
sorry, but if I'm anchored there first and a guy comes in too close, with a stern anchor, he's going to have to be the one moving away if doens't like it. all he'd have to do was release is stern anchor and swing out... if i can shorten my scope if conditions allow, i will but it's not up to me to move.
