I learn to use my sixth sense. As in, if I hear any wind, I check the anchor. I also learn to memorize things such as a particular tree out my right side window, a particular peak out the left. I'm about this far from that sailboat mast. I know in advance whether I'm going to experience a tide change. If I do, I make sure I do a check after the change as the anchor needs to run and reset 180 degrees off and there is the possibility it gets fouled in the changeup. Muddy bottoms like to stick to anchors, so when they pull out they don't set easily sometimes with all the muck sticking to the flukes. We don't have more than one tide direction change every 4 hours here in the PacNW so I typically won't have to check more than once a night for a current switch.
Don't forget the time honored tradition of sleeping, propped up with one eye out the window.
Also, depending upon depth of course, if I were to put out 10:1 scope I would be laughed out of about 90% of the anchorages in my parts. That would take up a good portion of the bay for 1 boat swinging room. I try to get 5:1 out, but if its crowded and conditions are calm I might not be able to get that out without playing bumper boats in the middle of the night. The trick of course is to know the weather report. If its going to blow and the bay is filled up, make sure you are upwind. Once all your neighbors get blown to the back of the bay, you have plenty of room to let out the extra scope. Humurous tone sure, but I'm dead serious. Put out 10:1 or even 7:1 in calm conditions and after all the other boats anchor at "normal" distances, you are guaranteed to play bumper boats by having such a wide swing radius.
We use a heavy anchor and lots of chain to cut down on scope for all but the worst conditions. Also, very serious about the point of anchoring upwind and letting out more scope in the middle of the night once the boats drag away from you, not before. Never get caught downwind when the wind is going to get going around 1am.
Depth of water makes a huge difference. Our tidal changes can move 12 feet of water in an exchange. That means that unless you are really really watching your tide charts, you don't want to anchor in less than about 20 feet of water if you don't want to find yourself touching bottom at some point (always 2am). I try to target about 25 feet of water, but often we are in 30-50 foot, more if the bay is crowded and I have to find deeper water. On a 30 foot bottom, that means over 150foot of chain to maintain 5:1 scope (remember to allow for your bow freeboard height). That's quite a bit of swinging room. Those of you who can anchor safely in less than 20 foot will get away with much less swinging room for the same scope. Keep this in mind. Also keep in mind that if you are in shallow water, less than 20 foot, your rode angle is going to be much shallower, and greater likelyhood that somebody might foul up in your anchor rode. If I'm anchored in 30-50 foot of water, typically you could come within less than a boatlength of me and not get fouled. In cases where your rode angle is shallow, you might want to get in the habit of clipping a weight onto the line to help keep the rode near the bottom.
Mainly though, if the wind blows at night, plan on keeping a watch and sleeping the next day.
