Anchoring questions
Thompson gunr
I have a "fluke" style anchor that I use for my primary anchor. I boat in fresh water rivers. Last weekend I was boating on the Licking river in Ky and dropped anchor in about 22' of water. When it came time to get under way I found it to be stuck. No amount of pulling in any direction would free it. Since it was a warm day I put on my dive skin, flippers, mask, and snorkle and dove down to see what was going on. I found that I had dropped the anchor into a tree root which had completely surrounded the anchor. Short of diving down every time an anchor becomes lodged, is there any other way of freeing an anchor in such a situation or is it normal procedure to cut the rope and buy an new anchor? BTW, after I got the primary anchor free I had the same basic problem with the stern anchor which is smaller but the same style. This one was able to be freed by boat power instead of diving.
You could try using a trip line on your anchor. Or perhaps try one of the types of anchors that are self tripping.
a trip line attached to the other end of the anchor is the best solution. tie a float to the end and pull on that if your anchor gets snagged.
