Anhydrous lanolin...where?
jamsac
To rehash an old topic, anhydrous lanolin. I have read about how to use it, and where, and the great results, but apart from Ebay I was just wondering from where you found it, particularly in larger quantities, like 1 pound +. My local boat guy has, uses and can only get a product called Lanacote in up to 10 oz jar for $$$. Any help greatly appreciated as I will floating in salt all summer.
Thanks, James
I get mine at the RX .I was told by the doctor that women use it when brest feeding. A 1 oz. tube is 2.43 and 4 oz. will do my single prop with 2 coats,it will last me for one year and does a very good job.
i bought a 5lb tub last year for about $50-$60 from a web source
I will try to find the details
Google Anhydrous Lanolin. There is a web site I think link to ebay or Amazon. I bought 5 lbs this Spring.
TheoMD, I did that already and found the links, but they just seemed to keep sending me around in circles, no real outcome.
I have saved the ebay supplier's link, but they don't ship to the great white north.
Abalmuth, I anxiously await your details.
James
James:
I bought my products from Horton Lane (ebay express) but I see from their website that they are "taking a break to be with their young children." Is there a reason the other companies won't ship to Canada???
Use lanolin to coat running gear/tabs to prevent fouling. Seems to work better and be much cheaper than Trilux prop and outdrive paint.
Ted
I bought a 5 lb. jar 2 years ago from an ebay'er, but I can't find the details. I didn't have any luck finding it at a pharmacy. Most places pointed me to diaper rash ointments, which have it in them, but that's not all that's in them. Anhydrous lanolin seems to be a soap-making ingredient, so maybe you can find it from a supplier of that kind of thing.
When I read about this stuff, I found that there are different types of Anhydrous Lanolin - since this is the first time I'm using this stuff, I went with http://www.prop-shield.com/ (prop shield) even though it's pricey as compared to the cheap stuff. If it works, I'll try the cheap stuff next season to compare the two.
WOW- this stuff is about $100 a pound
Where pure anhydrous lanolin is about $6 a pound and my results using it was the same as prop shield's photos
this was after almost a year in the water- the port prop has not been cleaned yet
P.S. Interlux has a Trilux "Clear" spray can anti-fouling back on the market. Last year they only had it in black and gray. It's $24. at Boatfix and $34. at the other brick and mortar Boat supply chain.
I used the Lanacote this spring. Can't testify to the results yet but the price isn't that bad. I bought the 16oz container for about $17 and still have about 10% left after doing my twin stern drives. Not as cheap as Anhydrous Lanolin but not bad either. Will have to see how well it works. My growth was pretty heavy by July 4th of last year despite regular use.
Thank you all for for comments and recommendations, I now have 3 other possible sources to approach. All seem to be $35-$38 for 5lbs. Shipping will be in the $30 range.
James
