Another docking situation
Gee, I understood what you were doing right off.
My first thought was to mount a cleat to the dock at the mid point and attach a permanent dock line. Run it to the end of the finger and attach to the end cleat with enuff slack to reach a height that's easily reachable from your cockipt. erect a pole to hold the line at this height with some type of clip. As you enter your slip you can grab the line by hand or pole/hook and pull to the end of the dock. Easier if you use a cleat on the boat. After you're tight to the dock (midship to the end of the dock) use the line going to the center dock cleat to pull you forward. I hope you don't have a lot of current.. Should be single slip.
Paul, The bride has been working since we hit the ground at the airport! She will most likely be in Lexington all weekend working on the "Lexington Legends" account trying to get their paperwork straightened out. I will likely be there for a big portion of the day. Probably see you there.
David, Thanks for those great ideas! According to Paul (who docks at the same location as I do) the current should be MUCH more manageable now that the river has dropped over 17' (according to the dock owner) and the current has slowed. Maybe it was just a panic on my part that the current will always be like this.
Charlie, Good advice as always. If the current is not nearly as strong as it had been, I am thinking of using your idea since I can then easily use a line from a center cleat on the dock, wrap around the center cleat on the boat and pull myself in tight from the helm.
Thanks all!
