Another DSC Question
Crossroads
I have two fixed mount DSC capable VHF radios on my boat. One on the flybridge and one at the lower helm. Should I get one DSC number and program both with the same number or get two different numbers.
I think you only need one number. The number identifies you and your boat, not the radio.
I disagree. I have two DSC radios onboard my boat. I programmed each with different DSC numbers but with identical info. My feeling was that if you don't, when somebody calls you both radios will fire off their DSC alert tones causing a real racket if you are trying to talk. The unanswered radio will keep alarming until you answer it or until it times out. Both of my radios are placed next to each other for redundancy.
If I am wrong on the facts, would appreciate someone letting me know.
Jim D
You are only supposed to have 1 number per vessel.
I don't believe I've ever seen that written anywhere else.
Got a source handy?
IMHO I would stick with only one, here's my reasoning.
1) I would want to only distribut 1 number to contacts for selective calling.
2) I would only have 1 radio on at a time, for 2 reasons; 1 because 2 radios on the same channel often sets up an audio feedback loop much like a mike on stage getting to close to a speaker and this squeel is broadcast to everybody, 2 a transmit antenna in close proxsimity to a receive antenna sets up the possibility for damage to the sensitive receiver amplifier.
On the other hand I would get a seperate MMSI for a handheld for use with a dingy. Please bear in mind this is only my opinion I have not seen anything written about it. There is a similar but different post on another forum with a phone number you might try for some "facts." MMSI database administrator 800-283-2883 and asking for extension 3561
Cheers
If you go to the Coast Guard Navigation Center page under MMSI, scroll down to the heading "The Exhaustion of MMSI's" and read paragraph 3. The way I read it you use one number for all equipment on the vessel.
I don't think 2 numbers per vessel is not allowed, but it seems only one is required:
http://wireless.fcc.gov/services/index.htm?job=licensing&id=ship_stations
"Radios with Digital Selective Calling (DSC) Capability
If you have a marine radio with DSC capability, you must obtain a nine-digit maritime mobile service identity (MMSI) number and have it programmed into the unit before you transmit. Each vessel needs only one MMSI number. Prior to obtaining an MMSI number, you will be asked to provide certain information about your ship. It is important that you obtain an MMSI number because the U.S. Coast Guard uses this information to help speed search and rescue operations."
