"How do you like your boat? Any feedback would be great, thanks Jim."
Jim, I'm happy with mine. A good all around family cruiser and not too expensive to buy or maintain. Not too fast either, mind you, since the hull is thick and heavy. But a good solid boat. Easy to handle/dock - you've got a good keel and hard chines there and the engine spacing is wide, so it'll do what you want it to in most any conditions. Mine's been repowered, not sure if this one has been (looks like the old style Crusader risers) so obviously the engines would bear close inspection. The other thing about Pacemakers is, (maybe you know this) the windows. The only question is whether they leak now, or whether they leaked in the past and got fixed and how much water damage happened at that time. That they never leaked is simply not possible - it's a Pacemaker. Just one of those things they are known for. You'd want to look for softness in the foredeck or catwalks since those are wood cored. Really any wood near the windows you want to look closely at, and visiting the boat on a rainy day is definitely a good idea.
On mine the stringers are well encased in glass and solid - as long as this one didn't sit full of water, I'd expect the same. No wood coring below the waterline so it's likely the hull is solid.
The photos look clean. There's a ton of gelcoat on these so you'd be able to shine it up nice.
Good luck.
