As always I need help again..
hackalar
Boat: 1995 Silverton twin 454 xl throttle bodies.
Port engine: when trying to plane I run up between 3000 and 3400 rpms. The engine stumbles and drops down to low 2000's. I can slowly let off of the throttle and the rpms will start to climb back up some. I can feather it back and forth and it will adventually come up and stay up after cruise speed is reached. I have replaced all fuel filters, tested fuel pressure (15 psi) throttle body was rebuilt about for years ago. I have owned the boat 3 years and its done this off and on the entire time. Now it does it non stop.
Starboard engine: gets up on plane and runs fine for about 10-15 then stalls down to about 800 rpms. When I let off of the throttle it runs rough for a couple seconds then dies. I can start it again and it starts fine. This is a new thing. Happened the last two times I've taken it out.
Last spring we replaced both gas tanks because of leaks. So the gas is fresh and no water etc.
I wouldn't bug you guys with this but the closet mechanic is 110 miles from me. I need help!!! I'm lost. I will respond to anybody that answers this. Thank you so much in advance!!!!!!!
Port engine still sounds like a low fuel delivery problem. Like a Clogged Tank vent. Or something electrical in the fuel delivery system.
That Stbd Engine sounds like a fuel issue too. Could you tell if the Choke plate is closing while running?
Next time you get out and the Port slows down on you, loosen the Fuel cap and see if the engine revives.
One more thing that will drive you nuts is the fuel supply 90 Degree angle fitting at the tank.
If that's cracked it will have the pump sucking air through the crack.
That 90 might be right below the deck and walking on the Deck might flex the crack enough to give you problems.
If it were Ignition/Timing related you'd have Popping and spitting back etc.
To elimiate fuel issues, hook up engines to 5 gal portable marine tank and test run on that. If it is the fuel delivery system, engines should run good. If it is the carbs or something else, it will still run bad. Might at least eliminate fuel tanks/delivery system as a problem.
Great idea. Definitely sounds like a fuel delivery or maybe hot fuel problem. Since the Stb tank issue is new, you may have shavings floating around and getting picked up in both tanks. Sometimes the shavings will lodge in the check valve at the tank exit so check there. It could be an issue with fuel temp, do you have fuel coolers on the engines? If so check them for water flow. Check routing of fuel hoses, especially with the new problem after changing tanks to see if they are getting hot somewhere. Shield any possibility with alum foil to test.
Fuel pickup issues!
The reason I like the Chainsaw Filter in the tank is from experience.
Like some part of tape or 'other' left in the tank from new.
Every once in awhile it wraps itself around the inlet screen.
Speaking of a metal, fixed in place, pickup tube, a 4" long inlet screen would be minimum.
The "Chainsaw fix" is a long pickup tube of Gas proof rubber tubing, with a large filter on the end.
That will roll around as you go and very likely will not be stopped by whatever might be left in the tank.
That filter
How, are the plugs? Plug wire? Rotor? and Cap?
To me, this is where I start looking. It does not take much wear before miss-firing or cross-firing begins to occurs. I change mine out every other year. If you do a lot of boating you might need to do it every year.
Check timing advance I have 84 454's and had the advance springs rust out.
I'm going to boat tomorrow. I'm going to try everything suggested. Will up date beginning of next week. Thanks for all the replays.
454xl - what brand are these engines?
Our MerC TBI has a mechanical pump filling a Vapor Separator Tank (VST) that contains a bowl float, filter, and the high pressure electric pump that actually feeds the TBI injectors.
This makes me curious about the "15PSI" you mention. If it's supply from tank to VST, 15's more than you need but probably wouldn't hurt anything. If it's output from VST <<TO>> TBI, then I'd venture it's too low.
