My entire 40 years of boating, never played with or replaced a bilge pump. Probably needed to, but never checked them
So here is the deal,
I need to know how the "float Switch" is wired, as opposed to the manual use with the switch.
Logic would tell me the pump has a separate power + feed to override the float? What I see is that is not the case and am thinking all power seems to go through the float. Som if the float is bad, you cannot manually override.
Specific point!
Had water in the bilge, way above where the float should have kicked on. So use the manual switch, and it still does not pump. I did not have a volt meter with me so assumed the pump was bad. I removed the pump, brought it home and hooked up, a power source and the pump works.
Guess it is the float???
Specific point!
