Battery Charger
dritter
I am having trouble trying to figure out what is going on with my battery charger. I have the red going to a positive on both batteries and the black going to the negative on one battery. My battery on switch 1 goes dead when I use that. The battery on switch 2 charges when it is being used. If I put the switch on 'all' then both batteries charge. Anyone have an ideas? Why won't it charge when the switch is on number 1?
Duane
They both are grounded to the engine block. There is only one ground that comes from the charger. I thought about that, but they should make a complete circut since they go to the same ground.
Since both batteries are grounded together, my next step would be to swap the red leads to see if the battery charges with the other lead to see if you have a bad charger leg.
Paul,
Thanks for the idea of changing the leads. Why would the battery charge in the ALL posistion?
My guess is that the battery charger is connected directly to battery 2. Switching to "all" connects the batteries and the charger can charge the other one through the switch. Sounds like the lead that is supposed to go to battery 1 has a problem.
You DO have a dual-output charger?
It is a dual-output charger. I will switch them and see what happens. I guess I can run it on ALL.
Duane
Charging it on ALL is not a good idea. You are more apt to bring the better battery down to the level of the bad battery then charge up the bad battery to be good. Always charge one battery at a time. Best to find the real problem and fix it.
