Belt Problems
p_medic
When I get my engine running faster than 1000RPM it throws the serpentine belt. It was doing fine when I ran it last summer. All pulleys seem to be o.k.. The engine is a4.3 LX Gen+ with a 5 3/4 pulley. This is not the original pulley, the original was plastic and had to be replaced. Do I need to get the idler adjustment as tight as possible? I don't want to put to much pressure on the various shafts. Also I need a new belt as the edge on the current one has been cut due to it being thrown. Which is the best way to go, get a kit with a new 4 3/4 pulley and belt or just get a belt?
Thanks ahead of time....
Tom
Yep...the replacement pulley is made of metal. Belt tension should be tight enough so that by pushing with your thumb you get about 1/4 - 1/2 inch deflection.
