I need a wiring diagram for a two switch bilge pump.
Starting at the pump is a Rule 1500 with a Rule-A-Matic Plus switch.
On the bridge there is a momentary "on" switch and a status indicator light that is supposed to be lit when the switch is held over to the "on" position to manually run the pump. Only two possible positions on this switch.
In the salon is a three position Rule switch with "on" on the left, center for auto, and "off". There is a status light here too
The problem is that someone (have not had boat very long) has has installed the three position switch upside down where "off" is momentary and "on" stays on along with the status light. The wording is not upside down.
The bridge switch to manually run the pump will not work unless the salon switch is in the "on" position and the status light is on. Remember the toggle stick is upside down where "on" can be left on. The bridge status light is also lit all the time that the salon status light is lit. The pump cannot be run manually from this salon switch.
If I put the salon switch in the middle position both the salon and bridge status lights go out and the float will not run the pump nor will the bridge switch run the pump manually.
In the bilge above the pump is a junction box where all the wires come together. My mechanic suspects that there are a couple of wires in the wrong place on the box.
Can someone draw or point me to a link on how a two switch system should be wired?
This is one of those "I would like to catch the idiot who did it moments"
