Blocking and outdrive question
jodon2
When I block for the winter, I usually block high enough to keep the drive in the down postition. This year I plan on taking the drive off for the winter for service. I plan on blocking 1 block lower. Can the drive be removed it it tilted up some? Thanks.
Joe
Best to remove from the full down position. Easier since the driveshaft and coupler are fully aligned and the drive slides right off. Also less risk of bending mounting studs. Don't forget to disconnect the pitot tube.
Yup, or remove/replace while it's still on the trailer. Either way, it's safer and easier for the reasons mikey said.
