Willie is correct in this. Do not remove the trailer from under the boat. There is a way to get the entire bottom cleaned and painted, as explained below:
If the trailer allows:
1. Drop the front of the trailer all the way, elevating the Transom.
2. Place blocks under the Transom to leave about a 1/2" space.
3. Jack up the front of the trailer (the Transom will now rest on the blocks).
4. Clean and paint the area that normally rests on the rear of the bunks.
5. When the paint is dry, drop the front of the trailer, again elevating the Transom.
6. Remove the blocks from under the Transom.
7. Jack the trailer up all the way, dropping the Transom.
8. Place blocks under the Keel as far forward as you can.
9. Drop the trailer so the keel rests on the blocks to support the boat and give you about 4" of clearance.
10. Clean and paint the area exposed.
11. Raise the trailer to remove the blocks under the Keel.
12. Set the trailer so it is in the normal attitude.
13. Clean and paint whatever is left.
14. Done.
The boat will always be stabilised by at least 3 points of contact with supporting members.
It is best you do not place your hands between the boat and bunks at any time.
