Blocking nightmare
BillyBo, many of us put the boat's bow on the beach for a few hours, to go to a restaurnt etc. This is very common many places in the South East and Gulf coasts. As for running aground--if you haven't done it--you either haven't boated long enough or in enough places....I have accidently put deep draft boats aground in the Atlantic ICW, the Sacramento Delta, on a peak rock off Turkey, and intentionally off Guernsey Island & Brittany, France,(When the tide goes out 25 feet, you secure the boat to the quay and let it take the ground) and careened the boat in Alaska and Panama to scrub the bottom and repaint.
I don't think that any one would check all blocking locations as you suggest, but there are other instances of boats where there was structural failure from blocking---I agree that any boat which will not take blocking would not be a good purchase.
This sounds like a good reason to use the large styrofoam blocks to block your boat up with. They mold to the shape of the hull as they crush a bit under the load and then spread the load over a larger area.
Good idea! Putting too much weight on a too small support area is asking for trouble
thataway4
I have been boating for some time now, the reason I do not run aground is, we are on Lake Ontario, very deep lake, except near shore, ONLY IDIOTS GO TOO CLOSE TO SHORE.
I did not suggest to do all the blocking locations, I was explain what a dumb response I got from rduhon Quote:"but I would definitely scratch a boat off any short list
if it would crack or crush the hull when it is sitting on blocks"
I was trying to explain, unless you do the over the top checks, how else would you find out???????
Maybe you and rduhon can tell me how YOU would know if the hull was going to breach before you bought it!!!!!!!
P.S. I like Capt Bill1 response, very informative and usefull.... Thanks
Quite an intelligent response BillyBo: "Only idiots go close to shore" (caps left off, since there is no reason to shout). lol, You asked why people would put a boat aground, and I gave you a number of instances from my personal life (67 years of boat handling and over 230,000 miles at sea and inland waterways) where I put boats aground--several accidental, in areas which have shoal water in the marked channels, and one where there was a rock which was unmarked on DMA charts.
To answer your question how I avoid a hull which might be defective?--I buy high quality boats, and I have the capability to do ultrasonic testing of the hull thickness and structure. Some boats are specifically built to take the ground. As I noted, I put often put the boat's bow on the beach when I go ashore--it is a Gulf coast and Florida thing.
In my opinion any hull which breaches when you block it is defective and poorly built.
I would scratch the original posters brand of boat off my list, because I would rather learn from others mistakes.
Before we bought our boat, pulling her out of the water and blocking it was all part of the checks. That his now I know ours wouldn't crack.
It was done by a the ship yard. If it would have busted the bottom, the owner would have had to keep his
boat, we wouldn't have bought it.
In my opinion, if it cracks or busts the bottom when it was done by professionals, it was not built right.
We go close to shore a lot, never where there are rocks, just sandy areas. I have never run aground when running a boat, on accident,
but I have beached a couple of boats, many times for parties.
I never had to do it, but I know people who purposely grounded their boat in order to keep it from sinking.
You might consider my opinion dumb, but my boat is up on the yard right now, blocked up, for close to a month, in fine shape.
I am sorry if sound snippy, it was not my intent, however, I started this post with the intention of warning people about sling marks and blocking location not being the same.
My comment about "Only idiots go close to shore" refers to here in Lake Ontario, we do not have many beaches that we can beach our boats on, the shore is usually rocky and our lake drops aroung 3' from begining of season to end, so an area that may have been deep enough in June may be an accident waiting to happen in September.
I watched my boat settle down into the mud after Hurricaine Rita when they let too much water out of our pool on the Ohio River. She sat there for about an hour on her bottom and running gear. Did hurt a strut but the hull was fine. Sometimes you don't have any control over beaching.
BillBo
If I read the posts right it sounds as if the boat was properly blocked. 1 on stern an one on keel towards bow then 2 stand on bow...I think you also said you found there was a patch in the area. My concern is was the area checked completely for possible water infiltration and other areas weakened. I am concearned that the damaged area was not prepared correctly the 1st time and there may be other hidden damage in the area. We had a boat here in the marina several years ago that had something similar to this and when the insurance company examined the boat they totaled it.
A year or so ago, a small cruise ship was in the ICW and hit something that put a hole in the bottom. The captain intentionally grounded it so it wouldn't sink.
The passengers were taken off,it was repained and refloated.
I went to the boat yard today to check out how they blocked boats compared to lift points. No one was there to explain.
My boat is the Chris Craft. When they lifted her I tied a rope on the stbd rail marking the packing gland location.
On the Cabo, the lifting tags were just ahead of the rear block and just behind the front block.
On the Searay 270, there was no visible lift tags.
On the Chris Craft 281, there are no lift tags.
On the Pilot boat, there are no lift tags.
On all boats, the front block was located at the most forward flat section of the bottom.
It looks like the rear blocks are located at the end of the keel and/or below the engines.
The blocks look evenly spaced along the boats.
The Searay is an I/O.
The Cabo and the Chris Craft are Inboards.
The Pilot boat is jet drive. It is also has an aluminum hull.
The jack stand were at different areas on each boat.
On my Chris Craft, they looked evenly spaced on one side and not on the other.
It may be due to moving to paint the bottom.
URL]
URL]
URL]
URL]
URL]
URL]
URL]
URL]
URL]
URL]
URL]
URL]
URL]
URL]
As you see sling marks and where they put the blocks under the keel have no relation to each other. Nor does where they put the jack stands.
By the way, those are nicer blocks then you see at a lot of yards.
They are stacks of treated 4X4's nailed or screwed together. They also have some big, old railroad tie looking blocks.
I was just stating observations on what I saw, not stating any facts.
There are usually a lot more boats in the yard, but they just set most in the water in the past week.
The smaller boats have 3 blocks. The longer ones have 4 blocks. Most are evenly spaced. They must have
a method to their madness.
They don't look like they are placed under any special areas, but look more evenly spaced.
The blocks are pretty wide also, they cover a good bit of area along the bottom, but don't cradle the bottom.
On my boat, the slings were behind the front and rear blocks. The rear sling was still on the very end of the keel.
Rduhon, that's similar to my boat. Mine is the 25ft model with a hardtop and no keel. It looks like you just painted yours. These CC's always look great right after painting!
To my surprise, Progressive Insurance requires we pull, block and pressure wash the bottom
before they send out an adjuster. They pay for it all, including the bottom paint job.
The damage was all above the waterline, some right above the waterline, but still viewable
while in the water. But they wanted to look for any damage that may have happened to the bottom.
We did not argue.
This blocking appears to be well done. When I pull a boat off a trailer, I use both large blocks (12 x 12" x 24" as one or two keel blocks, but the other supports (other than jack stands), I stack and secure 4 x 4"s this spreads out the load and is much more stable than stacking straight blocks (even spiked together).
Stacking 4x4s three across and spiking them requires a flat surface. Otherwise, it's best to stack 2 across because it'll make up for a certain amount of uneven mounting surface and always have some wedges around. Plus 2 4x4s spread a couple feet apart will more likely 'fit' a keel which aren't always straight and flat.
There were several boats blocked up like this that survived Hurricane Ike, Gustav and head with
Hurricane Rita(over 120 mph winds for close to 12 hours) in this shipyard. If it workded for all
the other boats during hurricanes, I am happy with the same thing for paint job and some gelcoat work.
