(Boat)Bottom paint remove.
DeeVee
Can a 7 years old boat bottom paint be remove and bring back the gelcoat look without the water mark on it or it'll be a "two tone" one?.
you can have the bottom paint removed with either soda blasting or paint remover.the later is very messey and time consuming. if your time is free the later is the ticket. it might be easier to remove the paint and apply a hard bottom paint if its a slick look you want.
I don't wanna reapply with another bottom paint, I like to bring the gelcoat back to match with the rest of the hull.
Doubtful that is going to happen. Most bottoms are sanded or "roughed up) to aid bottom paint adhesion. The only way you are likely to get that "gel coat" look is to re-gel coat it.
You would have to have it gelcoated or you could have it resanded smooth and have it painted. A few boat manufactures paint the gelcoat for a better finish. I pretty sure Fountain is one of them.
there is white bottom paint that may not look so obvious.
