Boat Carpet Question
MarkMuck
Our carpet in our boat looks good on the top. However, the rubber backing keeps coming off and leaves black powder all over the floor.... It's a mess
I hate to trash the carpet because it still looks good on top. Is there anything I can spray on the back or paint on the back to keep this from happening...?
Mark
I dont think anything will help at this point. However, if you replace it AND its secured with snaps, spraying armor-all on the back before snaping it in place will proling its life.
If it is not a snap in, I wouldnt use the armor all.
I have the same problem in two small areas on the boat. Next year, I'm going to try an anti slip pad that you can buy at Wal-Mart or Home Depot and place it under the areas that are abrading. We also use it for lining the shelves on the boat to eliminate things sliding around.
I had the same problem on a previous boat. The rubber backing started breaking down and sticking to the fibergalss deck. The carpet had snaps to keep it from slipping, so the rubber backing did not seem to serve a purpose.
I glued a thin canvas backing to the carpet. This eliminated the problem and did not cause any problems with slipping. Used a light canvas drop-cloth from Home Depot and some 3M spray adhesive. Stayed in place for severl years and never had another problem.
If you are ready for new carpet, Ping Rommer.
Is Rommer in that business?
I am looking at new carpeting.
No, not in the business but this year I made my own replacement carpets for the cockpit and bridge. Learned a lot and it came out great.
I'll see if I can find the link to the thread about it.
