Boat Mattresses
mintregila
We are considering the purchase of a new queen mattress and are not sure which way to go.
One company is Artisans Mattress. They custrom cut Tempur-Pedic mattresses to fit. Since we sleep on one at home, this seems attractive.
The other is Handcraft Mattress. They custom make inner spring mattresses with a hinge fold if necessary to access under-bed storage.
Nether company has a local representative so I would have to measure and make the template myself.
Does anyone have any experience with either company or the measuring process? Any feedback would be appreciated.
never had to have a bed custom made but we LOVE our innerspring mattress on our silverton.
Mark
I don't have his number But the Handcraft Mattress rep is Kevin and he is based out of the Manhasset Bay Marina 516-883-8411 - they should be able to give you his #
I cut open my existing mattress and sent in the ticking, they used this for the pattern.
Thanks Andy.
Last time I spoke with them, they said they didn't have a rep.
Mark, I contacted Artisans a month ago about doing the same thing. My current mattress is only 4 inches thick so they were going to slice the 4 inches off an 8 inch Tempurpedic king size mattress. I also needed a hinge in mine to access storage. I was told I could draw the shape and add in all the measurements from all corners, include a picture, and they would lay it out, cut, and ship it to me.
I live just 2 hours from them so I thought it would be better to drop off the old mattress for them to use as a template. Ball park price for mine was $2000. More than I wanted to spend but for a custom mattress probably in line with others. I may try cutting a large piece of egg crate to use as a topper to my existing matteress for about $75.00 and see how that works.
If you want to go cheap, JCpenny will sell you a firm piece of foam choice of thickness for 100 bucks. I used this and cut the shape with a serated knife while waiting for my custom one.. put a thick mattres pad around it and it works fine.. A little firm for my taste but it was realy pretty comfortable.
Thanks guys. We sleep on a tempur-pedic at home and are big fans. The mattress we have is pretty shot. We got a season out of it by using a memory foam topper but we're ready for something permanent.
I'd go with another Tempur-pedic if it were me. And they are guaranteed for 10-20 yrs too!
Silverton 34...Where did you get it made? We are heading for Ft. Myers for the winter.
i have a queen size OEM matress with the middle fold feature free to a good home. I replaced it with an air mattress but it is OK for what it is.
Remember on the Tempurpedic that if you sleep on your boat in colder weather the mattress will be like a rock until it warms up to room temp. Also, if you're feeling frisky this is a TERRIBLE mattress for sex. Good for sleeping but bad for sex. Enough said :)
I had tempurpedic mattresses made for my boat last winter. It's quite good, but with the reduced thickness it is a little too firm. We put egg crate on top (which we had the previous year), and that made it better.
Mint:
I called Handcraft Mattress when I needed a new v-berth cushion on my boat. They had an instructional video along with a template kit. I used the video and kraft paper (essentially what the kit was) to create a template. Very easy to follow instructions in the video.
I can't comment on their mattresses as I went to a local upholstery shop and had a plane foam cushion with Sunbrella upholstery made for alot less money than Handcraft wanted.
eric
For $2000 I'd rig up my own heated wire cutter. Slice it in half first, trim your mattress to shape from the top half and then do the bottom half for someone else. I agree, spring mattresses are more "recreational" than the memory foam ones...
Not sure about memory foam, but regular foam rubber cuts nicely using an electric carving knife. Just make sure the Admiral doesn't see you taking it out of the kitchen.
eric
