Boat name removal issues?
surfnboat
I am looking at a 2002 Boston Whaler. It has a giant name, in stick on letters on each side. Have you ever tried to remove these? What can of worms did you open if you did? Thanks.
Not hard to remove. But they may leave a shadow on the gelcoat.
Heat gun or hair drier works. Then you can remove the left over adhesive with Goop Off or acetone. There are other products as well that I'm sure others will post about soon.
You can get them off easily if they are vinyl. As mentioned, a hair dryer. I wouldn't use a hear=t gun. If you leave it too long, you can scorch the gelcoat. Less of a risk of that with a hair dryer. And as mentioned, you may have some remnants left behind. Are you going to apply a new name in the same spot? I would think a good compound would even out the shadow a bit, but I haven't done it.
I used this to remove the boat name and home port -
3M™ Stripe Off Wheel
This works great! No scraping, no heat. I had everything off in about 4-5 minutes.
heat gun (careful) or blowdryer. then some acetone to remove any glue residue and 3M finesse for the shadow.
no big deal, takes a few minutes
The problem isn't removing the lettering, the problem is renaming the boat. There are strict guidelines in boat renaming, and if done improperly, the Gods of the sea will frown upon you and your boat. Google boat renaming ceremony, or someone here might post the proper procedure.
P.S. Try an old credit card for scraping.
I can vouch for the boat renaming issues. This boat keeps her name.
Oven Cleaner works best to remove the vinal (use gloves!). Use WD-40 to remove the goop. Remember to make the proper offering to Neptune before re-naming!
I've heard of using oven cleaner to remove a painted name, but not vinyl letters.
Type-A is absolutely correct. 3M stripe off wheel (eraser wheel) works great. I just used it to remove the home port on my boat. You can purchase for about $30.00 from a auto body parts supplier or on the internet. Do a search for 3M stripe off wheel. It works on a standard 3/8" drill.
One hint I might give you is this; If it gums up after a while of use, just run the wheel across a clean rasp (or anything rough) to clean the built up vinyl off of it.
This is what body shops use to remove everything vinyl. Good luck and remember to follow the correct tradition for re-naming or ?????
If this is gel coat that you are removing painted name on, then after use the oven cleaner you are going to want to use distilled vinegar to get rid of the yellow stains that will be left on gel coat. Then there will be a shadow of the name left, sometimes the sun will take care of that in time , sometimes not to get rid of the shadow wet sanding the area and then compound and wax and you will have a fresh transom for the new name.
You must do the renaming ceremony!!! On a previous boat, we did not do the ceremony and we had alot of issues with the boat. Purchased several since then and have no real issues. Go to Google and ask for Boat Renaming Ceremony. We made it into a big party on the dock...all enjoyed it!
