- Nov 30, 2006
- 24397
- 230
I want to buy a used trailer for my '99 Wellcraft Martinique 2600 (used because I don't plan to trailer it that often). I know the obvious things like making sure the weight capacity of the trailer is large enough but are there other key things to look for to make sure the trailer fits the boat?
As an example, I put my boat on a friends trailer but the eye (where you attached the wench cable on the boat) seemed to be much lower on the boat than his because that eye wouldn't go between the 2 pads where the bow of the boat hits when the boat is fully pulled on the trailer. I ended up having to run the cable below these pads (rather than between them). Does something like that matter or that doesn't matter as long as those pads are in contact with the boat?
