bottom/outdrive paint
sevo
I am new to this site and find it really
helpful...thanks to all of you!
Sorry if this question has been beaten into the ground already but...Is painting the outdrives as effective against corrosion as the Volvo composite drives (XDP). I am looking at a 29 foot Chaparral with the option and it would be wetslipped full time in saltwater.
There is no paint that I am aware of that would yield a total anti-corrosion result similar to a composite drive.
I have always used Interlux Trilux paint which is designed for aluminum drives and does a good job as long as you run your boat regularly and or brush the drive once a week to keep the growth from getting started.
Do not use a standard bottom paint-get the stuff created for your aluminum outdrive and you will be fine.
DaveS
Thanks Dave.
Sounds like I should go with the composite drives if the option is available.
Anyone found any major issues with the Volvo composite drives?
If you are going to keep your boat in the water, you will still need to paint your Volvo Composite Drive(s). Albeit electrolysis issues are mostly averted due to the composite material utilized; barnicles, slime, ect... will still make their home on your units. Here's what my engine's (8.1 OSI-XDP) owner's manual has to say about XDP drive painting:
Painting the Drive (XDP Only)
A)Preparation
1. Remove all marine growth.
2. Use sandpaper or sandblast to remove loose
paint and corrosion. Use a medium grit aluminum
oxide sandpaper. If sandblasting use 55 - 25 grit (0.2 - 0.7mm) aluminum oxide blasting media.
3. Wash with hot water and detergent to remove all traces of oil and grease.
4. Roughen any painted areas that will be re-coated with a medium synthetic scouring pad or equivalent (i.e. 3M Scotchbrite™).
5. Rinse with water thoroughly and allow to air dry. Do not use a rag to wipe the area as some rags may have silicone.
B)Paint Application (XDP Only)
1. The part should be painted soon after it dries, or at least within 24 hours.
2. Make sure that the surface is fully dry before painting.
• Do not blow dry the part with compressed air
unless it is completely free of dirt, oil and water.
• Do not heat the part above 140°F before painting.
• Do not touch the clean surface with bare hands
before painting.
• It is best to let the part air dry, but if you must wipe the surface to speed up drying, use a lint free wipe not treated with anything that may contaminate the surface. Do not scrub the surface — wipe very lightly.
3. Where the primer coat is thin or where the surface is unpainted, prime with Volvo Penta primer P/N 11415627 or an equivalent epoxy primer (i.e.PPG® Super Koropon). Do not apply primer over a glossy hard finish coat without roughening.
Primer solvents must be allowed to evaporate
and the primer must harden before applying the
finish coat. Follow the label instructions for
method applications, drying times, and proper
disposal of residual product.
4. Apply finish coat. Volvo Penta Parts Catalogs list part numbers for the finishing products that apply to your Volvo Penta product.
Also, here's a link to what Interlux suggests: http://www.yachtpaint.com/Images/15_25432.pdf
Hope this helps,
GW
