Originally posted by MikeeH
The maintenance schedule for the bottom of a boat in FL has little relation to the recommended maintenance of a boat bottom in NY. Hard paints lose their effectiveness if out of the water for more than a month or so... most FL boats stay in the water so they can go several years on the same dose of hard paint. Boats in the north that are hauled for months at a time are not good candidates for hard paints for the same reason that they are acceptable for use in FL. If your bottom has hard paint and you haul for the winter, yes, you do need to repaint if you expect to keep a clean bottom. Ablatives, on the other hand, wear away over time as the boat moves through the water so, even after being on the hard, once launched the paint will slowly wear away and continually expose fresh biocides. In the north a couple of coats of a quality ablative should last a few years and you will never need to "sand to the gelcoat" to get rid of the build-up of many coats.
