Bottom Paint...removal
soldsoul4foos
Ok, I've made the brave decision to remove the bottom paint from my 27' baja myself. I know it's going to be alot of labor on my part. I have a few questions before I get started in a couple weeks.
1. AFter talking to a tech at a boat shop i do computer work at, he recommends sanding it off just to the point of the gel coat, then sanding with finer and finer papers to a smooth finish. How should I then finalize the refinishing of the gel coat? Or is just wax the last step?
2. Is it possible to pressure wash the majority of the bottom paint off? It looks/feels like it's already flaking off. I'd certainly be down for buying a good pressure washer for this purpose. If so, what pressures are needed to do the job?
3. Any thoughts from experince on pitfalls I might get into? :(
Thanks in advance for any advice....wish me luck.
Regards,
Bill--Sebago Lake Maine.
Bill, even though I've done this myself, I'm far from an expert on the subject. First, if the existing paint is an ablative, you can pressure wash it off. If it has a barrier coat, be careful not to remove it, unless you plan to complete the process all over again.
If you plan on simply adding new paint identical to what's already on the boat, just sand the surface and paint. You wouldn't have to get down to the gelcoat to add paint.
Pitfalls - using too coarse grain sandpaper and the wrong procedure can cause gouges in the gelcoat and worse... Perhaps someone will have a better answer soon.
What is alblative? My plans are to remove the bottom paint completely and not use it. I'm in fresh water, no need. Thanks.
Paint that's designed to dissolve and disappear over time to prevent growth attachments to the hull.
So, the boat will not be wet slipped? If you're going to trailer the boat, bottom paint may not be necessary, but even in fresh water growth will accumulate on the bottom and around the waterline if left wet, sometimes in less than a few weeks.
Well, it's ugly and it reduces speed ever so slightly. I've had boats at this same lake and never had bottom paint before without any problems. A wash once a month does the trick. I'm just curious what the best way to refinish the gel coat after I remove the bottom paint. Thanks :)
If you're not going to re-paint, then I would not sand at all. This will damage the gel coat and cause you big problems later on. I have used chemical bottom paint stripper with good results. Once the paint is off, inspect the bottom to see what shape the gel coat is in. If it was sanded before it was painted in the first place, you may be better off covering it with anti-fouling paint again. I don't see how you can sand it off just to the point of the gel coat. Once you have the paint off with the chemical stipper, you may just have to wet sand to polish the bottom and then go on to compounding etc.
Though the process can be reversed, most people consider bottom paint to be permanent. I believe that is mostly because removing is is such a pain.
Look at what you are reversing: they scuff sanded the bottom to accept the barrier coat. then added a tenacious barrier coat, followed by one ( usually more ) AF coats. As stated above, after you get the added coats off, you will need to refinish the "prepped" gelcoat.
As the paint is already flaking off, then you have nothing to lose and everything to gain by first pressure-washing the bottom trying to remove whatever is loose.
But first look carefully at where the paint is already flaking off to see if there are any signs of sanding or abrading of the gel-coat. If there are no signs, then you would want to avoid sanding now for obvious reasons, and pressure-washing makes perfect sense.
Dealers tend to take the path of least resistance in prepping a bottom by cleaning it first to remove the mold-release agent and then applying the etching coat followed by a coat of bottom paint. Over time, it flakes off which is what you seem to be describing.
Chemically removing whatever is left after pressure-washing would be the best way to complete the project, but you must take great care not to damage the gel-coat. You would need to strictly follow the manufacturer's directions as it pertains to application over fiberglass/gel-coat, and you'll need to work quickly to remove the paint over which you spread the remover.
Be patient; take your time, meaning, do a smaller area as opposed to a larger area at a time and use a flat, fairly rigid tool to remove the paint. If you use a scraper, then you'll need to keep the blade square and sharpened, and remove the paint by pulling the scraper toward you. If you have various size strake widths, then you'll also need a tool to accommodate that particular width whether it's the knife or a scraper. Personally, I would not use a one-width-serves-all knife or scraper because of the propensity of gouging the gel-coat.
Again, if the bottom is "fresh", that is, with no previous abrading or sanding, and if you are careful with the removal of whatever paint is left to remove, then when the paint has been removed, you should be able to just clean and wax and be done with it. If the bottom is already abraded from this previous bottom paint application, you'll need to decide what to do to satisfy yourself. And one of the choices will be to repaint the bottom.
That's my story, and know the rest.....
Just remimber that bottom paint is some nasty stuff that is made to kill or stop things from growing on it. If you sand it the sanding dust could cause you some trouble to your lungs. I looked at the lable last year after I painting my bottom and , they want you to cover all skin, where a mask and gloves just to put it on. If I was goin to remove it , I park on a large tarp so nothing would get in to my yard, next user peel-away it's about 54.00 a gallon ,strip as much off as possable then paint over it with a topside paint color that matches the boat. then fold up the tarp and throw it away. drive the boat off the tarp first. But to play it safe talk to a paint expert, they'll know what would be best.
SAFETY WARNING! Bottom paint is nasty stuff and so is the stripper. Wear Tyvek suits, rubber gloves and a respirator, and I mean a good full face respirator with face shield like the 3M 6000 or 7000 series. You'll want to have a box of disposable nitrile gloves and several tyvek suits, you're going to get dirty.
I went the Peel-Away route a few years ago. I had at least a 15 year build up of old paint to remove. First, I pressure washed to get everything off that was loose. I used a rotating zero tip on a 3500 psi washer. It took off alot of loose, flaking paint. I then removed the boat from the trailer (26' boat) and blocked up on a large tarp. I then applied the marine Peel-Away with an old putty knife. Wear that tyvek suit, gloves and mask again, you're working upside down and the stripper is the consistancy of heavy mayonaise and will drip on you. Work in small areas, keep the product thick and wet and apply the speciall paper with gloves and an old paint roller to make sure it is well stuck to the stripper. After doing the entire bottom, let it soak at least 24 hours, just be sure the stripper does not dry out. Come back and remove the paper with a plastic scraper. I used old plastic windshield scrapers since they will not gouge the gel coat. Oh, have a generous supply of trash bags and a case of paper towels. Again, wear your protective gear! Work in small areas and after you scrape off all the goop, Wipe with paper towels. This will leave you with a smeared looking bottom with the gel coat showing. Now you can sand or repaint. If you wnat every last bit of paint off, then you'll want to wipe the bottom with a thinner to get the last residue. Be careful with the thinner, it will have fumes so wear full protective clothing mask, suit, and gloves. Also, the thinner may be flamable, so extinguish all sources of ignition and work in a well ventilated area!
As you can see, this is a rather big job. It took me over two weeks working nights and weekends before I was finished barrier coating and bottom paintig.
HAVE FUN!
So...just went to lowes this morning. Should I purchase.....a) power washer #1-3000psi, 2.7 gpm, $399 or b) 3800psi, 4gpm, $999. What do you think?
Has anyone tried soda blasting to remove bottom paint? If so, what kind of surface does that process leave behind ? My boat has two or three coats of 'hard' botom paint. I believe the dealer just painted right over the gel coat, without any prep work, as there are spots that I stripped with chemicals where you can't tell the difference between the hullside and the newly de-painted area. But it took a very long time to clear a very small area - and I'd like to get all the paint off, and have the bottom clean enough that I don't have to repaint. Is this possible with soda blasting, or will that leave a rough bottom? The soda blaster guy claims it will leave the gel coat in perfectly clean condition, but I tend to doubt him.
