bulkhead repair
marg
'76nChris Craft 33' Offshore
We've removed rotted bulkhead. Thought I was going to use Teak Laminate but mechanic commented that he didn't think I would be happy with laminate and should fiberglass. Anybody with experience using laminate? We wanted to restore boat to original specs which was probably Teak. Considering laminate for weight and price. Looking for opinions and ideas.
I have teak laminate on the inside. Looks good. I would be conserned using it on the outside where it is subject to weather. Not sure how many times you could refinish it as the laminate is relatively thin. Good luck.
Don't even think about laminate outside. You would just be wasting your time and have to do it over soon. If you want wood, do it right.
I would use Ply soaked good with CPES and then epoxy ipe' tongue and groove over that. The ipe' wont rot and looks like teak.
Marg:
I also have a COHO. The original bulkhead was made from plywood with a thin laminate on both sides. I didn't completely remove mine as you have done. I only repaired the sections that were rotted out by fiberglassing in sections. When I finished I sanded the exterior side of the bulkhead and faired it so it was smooth. I followed that with white paint. The original trim around the windows is teak. I reused the glass panels and teak trim.
I noticed the interior cabin sides on your boat are colored white. Is that paint or some type of wall covering like wall paper?
Eric
That's what my husband wants to use Ipe. He's a floor guy. I wasn't sure what it would look like. Think I like that idea if it looks like Teak. I love the teak look. Where did you get the ply soaked with CPES?
Eric: It's a wall covering.
I would fiberglass it myself. The Florida sunshine is tuff on wood as it is and will require constant upkeep. I can understand keeping it original as I am restoring a 1965 Mustang and want to keep it original. The boat is exposed to the weather so I think I would just trim it in teak and it should look nice. If you really need the teak look may be look at some of the plastic teak laminates such as N U teak.
Marg, CPES is Clear Penetrating Epoxy Sealer that is very thin like water that is designed to penetrate into the wood fibers. You can get it from The Rot Doctor or order it straight from Smith's. If you are just painting the interior then I would use MDO for the plywood with the face inside and then treat the outside like I've suggested.
Thanks CA for the info. I do love the look of wood, heart says go with keeping it original, brain says go with glass for ease of care. Husband says the epay is indestructable. We're going with that idea. I'll post pics when completed. Thanks everybody for the input. Still the best forum on line.
Nice boat Randy. How come we don't have a CC forum on Boater Ed?
Thanks, She was a little ruff when I first got her but have most things repaired or replaced over the last 2 years. PO had painted over all the teak and I have stripped most of it back down to the teak. Fixed a few soft spots on the flybridge so she is comming around. I guess there are too many other CC forums. Check out the CC commander club. A couple of guys that worked for CC for years are on there and can answer a lot of questions about the old Chris Crafts.
We have a soft spot on the flying bridge that were going to try to repair from the salon ceiling. Took the headliner off already, it was trashed. When the bulkhead came out we found rot under all the bridge stantions. The joys of reviving an old lady. I do think it's worth it.
Marg:
The flybridge deck/salon roof is balsa cored fiberglass. If the P.O. drilled any holes it is probably water saturated. Look for rot other places besides under the stanchions. My deck was complete mulch once I got into it. Rebuilt mine with cold molded plywood/fiberglass from up top.
eric
Eric,
We've drilled peek holes and it doesn't look too bad. It is definately balsa cored. There is one 1 1/2' diam spot in middle of deck, under helm chair. I'm hoping we don't have to replace entire deck. Any pictures of yours?
Marg:
Unfortunately I don't have any photos. Your deck sounds like it is in better shape than mine was. The entire core of my deck was rotten and the deck lost its structural strength as well as it's upward curvature. It sagged creating a place for the water to puddle on top, seep in further, and cause more rot.
You may be able to drill some holes in the deck from below in the cabin and shoot some epoxy into the soft areas to make a repair.
eric
