Canvas repair
glenncal1
Hey all-My canvas cockpit cover is starting to tear at the corners of the windshield. Probably from the friction of the windshield frame. Is there a repair product to use. I was thinking something like the iron on patches for jeans.
TIA
Try Eternabond -- they got back to me on an awning repair> We have found that the 50 ft Seam Repair Kit is a good solution. The WebSeal is flexible and has no memory. The UV Protector, which is also part of the kit, can be tinted at a paint store to match your awning.<<
Maybe more than you need. Friends have used the product with little complaint.
No iron on product is going to take the strain and sunlight of a boat canvas.
We use "Harbortime", (acrylic coated 100% polyester marine fabric) to reinforce all stress points in our marine canvas jobs.
Hey Larry, can you please contact me at adowlessrb2@gr5tgmail.com. I'd like to get an estimate on some canvas work on my 27ft regal, I'm in Rockville, MD and will be in OC for bike week Sept 13-17. thanks, Alan
Larry-do you sew that in? I would like to fix these 2 spots an reinforce some others.
What material is your cover made out of? HH-66 is a vinyl cement, but it holds pretty well with other materials. I normally sew in the harbor time when making the cover. Where are you located? Let me if I can help you out in any way. Stew
Stewart-the cover is your basic burgundy canvas. The boat will be moving to colorado at the end of September. Cover is in very good shape except for these 2 spots. The wood trim makes kind or a sharp edge at this spot. I would also like to re-enforce the back of the canvas where it goes over the transom.
If you can feel a sharp edge,..it will rub through,..if it's some what smooth over your transom, you should be ok. the best way is to sew the polyester in, but you could try the cement. I have seen people use pipe insulation from the hardware store and slip it over the edge of the windshield for extra protection,...but it can make your cover pretty tight to snap the snaps
