How do I search on Capitol Transmission Posts ?
I'm having difficulty getting my oil level correct on my Strbd side- I have M-105's.
my boat is a 1989 45 viking powered by DD 691 TIB's
I'm either measure to low or to high when I check it with the dip stick.
Also, my port side shaft rotates slowly when the engines are in neutral while the starboard side doesn't. Which one is normal ? I believe it's been that way since I purchased the boat back in 08.
