Carb Wedge
Shore
I replaced my I/O 454 merc with a inboard 454 Merc.This Merc has a carb wedge on it.
It's just a wedge under the carb and woudln;t be too much of a PITA to pull out but if it will not cause any issues then leave well enough alone.
We took the boat out and it has a top end bog.Run her 2/3rds throttle and she revs right up and actually planes out.Push the throttle farther and she falls on her face.She starts with a bump of the key and idles fairly smoothly.Never once stalled.It's certainly a case of too much unburnt fuel but there are other issues.
1..It has a old cap/rotor on it and it needs replacing badly.
2..It also has 4 yr old gas.
The gas and cap/rotor are getting replaced but if the wedge is of no concern then I would rather just leave it alone.
If this wedge makes these symptons then let me know.Not looking for speculation just someone that knows.
94 290 Sundancer single 7.4 B3.
In case you guys don't understand.My boat is an I/O and the donor motor was from a inboard so the carb used a wedge to angle is correctly.My 1st time seeing this but I guess it is rather common for inboards.
Pull it out so the carb will sit level. Might be contributing to your problem...
Larry
Remove the wedge. It is only needed when the engine is pitched toward the stern in a DD application. It may or may not solve your problem, but it doesn't belong on there in your application. Was this the first test of the replacement engine or did the problem pop up after the fact?
e-mail me...tgriffin36atcfl.rr.com
change the "at" to the ampersand sign of course.
