I want to change the carpet in My Carver. The old one is glues down but seems to pull up easy enough. do I need to remove all of the old glue or is there an easier solution?
I did my Carver last year. We removed as much of the old carpet in one piece for a template to cut the new one out. Then we used a small flat scraper to remove as much of the old glue as posssible with some Varsol to loosen it.I cleaned this as much as possible not 100% but at least when we put the new carpet in we new the base was clean and dry.The new glue had a good surface to adhear to as well. We were also worried about the old glue being dirty and maybe smell or mold after we put down new carpet. We also made sure the cuts were big enough on the new carpet so that all we had to do was trim all the way around the edges after we laid the new carpet a much more difficult task in the corners and curves around the floor but it is in and fits just like factory maybe even better
Wouldn't the tape lose it's stickiness in a damp environment? Plus the 'floor' side would have to be 100% clean and smooth to get the most effective adherence. BUT, I've never tried it...
