Originally posted by Ted Williams
I've had the 3126's for 3 years now, they had 1100 hrs when I bought the boat It's a 1999 Silverton) and now have 1860 hours (this includes 2 trips from NC to Bahamas). Only problem has been a cracked injector sleeve on the port engine (it was getting fuel into the coolant). Replaced all sleeves and injectors on that engine. Both engines run well and I have been pleased with performance. Mine are mechanicals, the 2001 may be electronic, which would be a plus.
My boat is 46 feet long and weighs about 28K pounds, so sounds similiar. I cruise at 20 - 21 knots and top end is 26 - 27 knots. While I don't really know fuel burn at different speeds, on the last trip using the engine hour meter I averaged about 13.2 miles per hour and burned 13.7 gallons per hour. I used a total of 2560 gallons of fuel over a period of 186 engine hours. My best guess would be about 2 - 3 mpg at 8 knots and .9 mpg at 20 knots.
There is good local CAT service and parts are readily available, although expensive IMO. The CAT service tech also charges $2.50 per mile each way for use of the van. For me that's $250 plus his time to get to my boat. I don't mind paying for his time, but that's an expensive van. Last time I offered to send a limo to pick him up.
Hope this is helpful.
