Changing a bow spotlight?
TJM
My 20 yr old bow mounted spotlight finally died. It was the Ø 6" Diameter x 12" long SS type with remote controls at the helm. My question is how easy is it to change the "ends" (light and controls) without access to the harness in the boat? Do the mfg's use the same color coding and wire gauge so an easy swap is possible?
Are you planning to replace the spotlight with the same manufacturer and model? I replaced my several year old Guest SS spotlight with the same model, they had changed the toggle plate setup but if I remember correctly the wire harness had plastic snap connections at both ends which were compatible. If you are planning to use a different spotlight tan your original you may need to determine what each wires purpose is on the old harness and splice the wires to the new light and toggle setup at each end.
Easiest replacement is to buy a wireless remote spotlight. Mine has a water resistant dash mount remote (can't loose it) and a handheld, both wireless. All you need is a ground, and a hot wire at the light location. It also has programable codes like a garage door opener.
I called the manufacturer (Guest) and found the nearest place that can rebuild the origanal spotlight.
