Changing Alpha One Impeller
NORMinCONN
Can someone walk me through changing an impeller on a 2000 Alpha one? This will be my first time doing it so I am a little nerves.
At the bottom of this page is g00gle's search. Search this website for alpha one impeller and you get lots of info!
It seems to be a pretty straight forward process if you are mechanically inclined.
Liz has is right on. Here's the Readers' Digest version (some details have been left out):
1. Drain drive lube.
2. Shifter in forward.
3. Remove 6 bolts (I'm pretty sure there's 6), and trim rams.
4. Drop lower unit off drive (gently).
5. Remove pump housing nuts/bolts, remove old impeller.
6. Insert new impeller.
7. Reverse above steps to re-assemble.
Again, this is the Readers' Digest version. It's fairly simple if you follow ALL the directions you find from a Google search. The first time I ever did it, I took my time and got it finished in about 2 hours.
Gen II, the trim rams stay put. Remember where the little red o-ring goes. 4 bolts are obvious. 1 under forward zinc, other under aft zinc. If it doesn't come free easy, you missed a bolt. Don't pound on it. google for pics.
Be sure to replace gear lube from the bottom with the upper vent open. Fill until you see the upper vent is full. This will prevent any air pockets from developing.
Thanks everyone. With everything I have now I should be able to do the job. This site is great.
If all you need to do is change the impellor then there is no need to entirely remove the outdrive. You are going to split the outdrive apart anyway, so why not simply remove the bottom half and leave the top half attached to the boat? Makes for a much lighter piece to handle.
Drain the drive lube
Trim the drive full up (so you will have ground clearance)
Remove 5 bolts holding the two halves together (one is under the trim tab)
Drop to lower half of the outdrive
Replace the impellor
Put everything back together
