When changing the therostats in mer 5.7 v8s(1992). After removing the cover, there is a brass sleeve that slides down over the top of the thermos. When they rust in place and won't
move is there a penatrating oil that will loosen it up to remove the sleeve? Or do you have to remove the housing and drive them out from the bottom. The orginal owner never changed the thermostats.
Thanks Ron
Thanks Ron
