I have a chysler m440 that I use an electric fuel pump to prime the fuel system, and after the engine starts I shut it off and the engine runs on the mech. fuel pump. The boat has been ran this way for decades without any problems. Lately, a couple off mins after shutting off the electric pump the engine surges and dies, unless I turn on the electric fuel pump, in which case the engine quit surgeing and runs fine. I've checked the p/u tube, fuel tank and vent they were clean and clear, changed the fuel filters and dumped the fuel out of aft fuel/water separter, which was clean the front fuel filter ( at the carb ) was dry and clean. Blew compressed air though the fuel lines, no restrictions I put a vacuum gauge on the input side of the fuel pump and disconnected the output side, when I cranked the engine there was maybe 1/4" of vacuum. after removing the fuel pump and manually compressing the fuel rod it had 5" of vacuum. Yes the push rod was lined up on the fuel pump "compression rod". this is a fresh rebuilt long block with 100hrs and this problem started about 30hrs ago. Any suggestions would be appreciated
