Soak in a large 30 gallon tub with a cup of muriatic acid to about 6 gallons of water. Leave soak for about an hour, rinse well with water and spray with WD 40.
They will look like new.
Abouttime
I haven't had any problems and have done this for several years.
But I don't mix it real strong and don't leave it overnite or unattended.
Just to be on the safe side.
Abouttime
I use toilet bowl cleaner and spray the prop down at the end of the season. Let it sit on the prop for a couple of minutes than hose it off thoroughly. If you do this in your driveway over concrete, let the hose run underneath the prop because any cleaner that hits the concrete stains.
