Um guys, I think Carver370 is talking about the air side of his system regarding the "residue." Carver, in this case, you want to check the air intake filters to make sure they are clean. This is usually a removable filter of some sort. Most can just be washed with a hose. The next problem spot is typically the coils that the filter is in front of. If someone has removed the filter or the filter is extremely dirty, then the coils may be dirty or plugged as well. Dirt in the coils will transfer to the ductwork and ultimately to any surface that is near the discharge vent (like your curtains.)
To clean, you should purchase some air-conditioning coil cleaner. This is also a mild acidic solution however it has detergents in it. You can google for air-conditioning coil cleaner. Follow the directions on the label but the basic steps are:
Shut down the system and open the breaker and secure so that the unit can’t start by accident.
Remove the air filter if it’s there. I would also cover any carpet or “finished” areas with plastic as this stuff tends to foam out when used. Be careful not to bend any of the coil fins while working on the unit.
Using a trigger spray bottle, spray the solution on the a/c coils. Cover the entire area of the coil. Let it sit for about ten minutes.
When the foaming stops (if any) spray the coil with a garden hose on a small fairly gentle stream. Keep an eye on the condensate pan so that it does not over flow. Make sure that it’s draining properly.
Usually, the condensate pan drains into a sump and is then pumped overboard. I prefer to disconnect the sump discharge hose and pump the stuff into a bucket and dispose of on land. The coil cleaner is designed to get deep into the coils and remove the dirt. Because the water that comes out of the coils will be a mixture of dirt, cleaner and water, you don’t want it to go overboard. Make sure to rinse all components so that there is no solution left in any systems. When you are done, reassemble the unit and filter.
Restart the unit and check for proper operation. If your unit had no filter installed, then the ductwork is probably very dirty as well. In this type of system, there is really no good way to clean the duct work except by replacing all the hoses. A BIG job. The blower unit may also be dirty. It is a fairly complex job to get to, disassemble and clean if that’s the case.
You should clean/replace the air filter at least every four weeks if you use your system a lot. Unlike a house system, it picks up a lot of dirt and can plug up fairly fast since it has more exposure to the outdoors.
When all is done, you should notice a marked improvement in the system and a reduction or elimination of the “residue” you spoke of. It will also reduce or elimminate any stale smells from the system. I have done the procedure on many systems and it has worked extremely well. (I used to be an a/c guy) Good luck with the project.
