Cleaning canvas
Showtime
Hi folks,
I took my bimini down before I covered the boat up in November to have it re-stitched. It needs to be cleaned as well and re-treated. I'm going to use 303 to treat it after I clean. What would be the proper way to clean it (Sunbrella about 8 years old)? Can I put it in the washing machine on gentle? Hand wash in the tub? How can I soften it, it seems a little stiff. Thanks.
Read through this: http://www.sunbrella.com/pdf/ccMarineTops.pdf
Don't do like a boating friend of mine did. He tied his canvas with lines to the back of the boat and put the canvas into the water. His plan was to drag the canvas through the water to clean it. Shortly after he left the dock, the lines snapped and the canvas sank to the bottom......
It makes for a funny story, but it cost hi a lot of money to replace it!
I read through the instructions on the link and want to add to it. Every other year I take down the canvas for the bimini and I mix a similar concoction as describd on the link. I use bleach and mild dishsoap in a big plastic bin. I fill it halfway with cold water and add the bleach and soap. I throw the whole top in and let is soak for about 20 to 30 minnutes. While it is soaking I use the boat brush to agitate the canvas for a few minutes maybe five or six times.
Then I pull it out and using the deck brush gently scrub both sides. I then hang it on the rail on the ramp to the dock and rinse it with cold water. Let in sun dry and reinstall. It comes out like new everytime. The canvas is 8 years old and still looks like new.
For spot cleaning on my boat cover, I used Oxyclean spray brushed it and rinsed, and it was just fine. It removed algae stains from a puddle of water that had set for some time.
Mo
If you go to Sunbrellas web site they will tell you to use a mild soap like woolite or something similar. If you keep it on the boat use warm water with the mild soap and scrub with a brush. Not the best way but it works. My old boats canvas was to big for the washer but I took it off and put it in the tub with woolite and kept it there over night. I agitated the water several times, drained and re-filled the tub. If you refill 2-3 times and let it sit in the sun to dry it will come out great. Make sure the material is dry before applying the 303. The 303 done with a couple of thin coats will make it like new. Do not put in dryer. Dont use a strong soap it will deteriorate the thread.
In between washings a good vacuuming with powerful canister vacuum and a soft brush will do wonders for Sunbrella. Vacuum the outside surface first, then the inside. I vacuum a couple of times during the winter to control mildew and as needed during the summer to keep it looking good. You won't need to wash it as often.
If your canvas is Sunbrella, see the link in Flutter's post for cleaning off mildew.
